Question about LG Televison & Video
Black and grey stripe down middle of screen LG lcd
The LG flat screen will change input, channels, volume and other settings by itself. That was not that big of a problem but now its having more issues. The picture on the tv is slow as if it is buffering or the cable isn't plugged into the cable jack securely. I have unplugged it and left it off overnight but when I turned it back on it still had the stripe.
TVtechmaniac
  • 140 Answers
SOURCE: Big black screen in picture
You have the CC (closed captioning) turned on and it is set to text mode. Look for a button on your remote labeled "CC" or go into your TV menu and make sure the captioning selection is set to "off".
Posted on Sep 19, 2007
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
BMW Rider
  • 232 Answers
SOURCE: LG 20LS7D flat panel LCD TV
Hi, go into your menu and turn off closed captioning, sometimes listed as "CC" instead of spelled out "closed captioning", this will fix ya, Happy Holidays, BMW Rider
Posted on Dec 01, 2007
  • 479 Answers
SOURCE: lcd tv screen turned black and i cant get any picture
its the problem of blown capacitors on rthe main board just check out the faulty ones with the help of multimeter and get it replaced.
Posted on Dec 10, 2008
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
My Panasonic smart tv had a thin blue line running down the middle of the screen earlier today. When a tv show was playing the right side of the blue line was fuzzy. Tonight I came home and now when I turn...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Mar 28, 2015 | Panasonic Televison & Video
The tv was giving as a gift in 2012. So I believe that I put the right model in. I was watching the tv and went to change the channel, when I noticed that the box with the channel number looked differ
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
Oct 21, 2014 | LG 32LD450 32 In. LCD HDTV
LG 37LC7D HDTV just went blank. Screen blacked out and green light is on but no response to input change, remote, volume, or channel change. I've unplugged it for several minutes in an effort to reboot...
My lg 37lc7d is having the same problem. My backlight is on but no display. Also the standby light blinks several times then the screen goes on but it's just all black. No a/v
Feb 08, 2011 | LG 37LC7D 37 in. LCD HDTV
Turns on and off by itself
If this happens on all inputs and you have disconnected the power and reconnected it and that didnt fix it.
Sounds like a logic board issue problem is LG only warrenties tvs for 1 - 2 yrs.
Jun 16, 2010 | LG 42LC2D 42 in. LCD HDTV
Purple line down middle of screen on all channels,constatly on,my tv is a LG 37inch HDready LCD, tv is 1 year old
I could do with a digital photo to be sure, however it sounds like the LCD panel itself has failed.
Sorry.
Mar 28, 2009 | LG 37LC7D 37 in. LCD HDTV
TV LCD THomson 26"
If what your saying is that there are vertical stripes down the screen, You have a screen drive problem my friend. This could mean you will need to change the entire main board, the screen driver board if it is separate on this set, or the main LCD panel itself. These boards do not have any parts available for them and must be replace as a whole unit. Good Luck
Mar 19, 2007 | Thomson 20LCDB03B 20 in. Television
Televison & Video Logo
101 people viewed this question
Computer Repairing
Computer Repairing
