Question about Spark Plugs BR4HS Plug 10/BX #3322
Where are the spark plugs located in a suzuki liana
Where are they located in a suzuki liana
Cant find location for thermostat in my liana Suzuki 2007
The Liana is called the Aerio in the USA. I am providing a link that will show you step by step replacement.
AerioStyle Reloaded View topic thermostat replacement
Semper Fi,
Z
Apr 30, 2017 | Suzuki Cars & Trucks
Hi I have a 2003 Suzuki liana, Iv put in an 2006 Suzuki engine into it and won't start and has no spark can you help me?
Did you disconnect the battery when you did the work? I am guessing you probably did. Your anti-theft system is invoked.
Disconnect the battery for 2 hours. Bridge the connectors for 5 minutes to fully dissipate any residual power. Put the key in the ignition, reconnect the battery sharply. Leave for 15 minutes to initialise.
Mar 08, 2017 | Suzuki Cars & Trucks
Where is the obd port located on a 2002 suzuki aerio?
Should be under a steering wheel on left or right.
Feb 05, 2017 | 2002 Suzuki Aerio
How many heater hoses does a suzuki liana 2005 need and what are they called?
welcome to USA forum with zero Lianas here,
just 2 on all cars, the core has only 2 pipes if you look there.
you need to look on the suzuki parts pages, (only 2 left usa)
why not drive to your dealer and ask them.
we dont have that here,
see them here,
no
https://suzukipitstopplus.com/Category/3-suzuki-service-manuals.aspx
see them here
no
https://www.suzukicarparts.com/parts/2005/Suzuki/?siteid=214820&searchText=
no parts here, no books here, no Liana here,
so.... why ask us?
if you told where you are location then magic can happen.
Jan 25, 2017 | Suzuki Cars & Trucks
Please could you help me with a photo where Suzuki liana's thermostart is located on the engine?
no year, no engine option stated, nor country. (we dont have em' in USA)
it's same spot all engines, mostly.
see radiator. see 2 big hoses.
the one that gets hot first, is the one that goes to the thermostat housing,. (under-which thermostat hides)
i have no idea which engine you have, at all.
the engines offered are:
1.3 L I4; 1.5 L I4; 1.6 L I4; 1.8 L I4; 2.0 L I4; 2.3 L I4; 1.4 L Diesel I4
yes, overwhelming,
Mar 21, 2015 | 2005 Suzuki Liana 1.6
Suzuki liana diagnostic port location
pretend we are blind.
what country.??
06, Liana.
what engine, Gas or Diesel???
there are 2 systems. OBD1 and OBD2
the hood stickers usually tell you which it is. (obd2 certified)
if car is OBD2 cert then any cheap but new scan tool works.
if car is USA car the OBD2 port is near the knees, 16pins
the spec, call out 1meter from steering shaft center. USA spec.
OBD2 is a USA spec. so...... where are you......
see here the car and all the variants.
see why we dont know, until you say so.
http://en.wikipedia.org/wiki/Suzuki_Aerio
Mar 20, 2014 | 2006 Suzuki Liana 1.6
SUZUKI LIANA 2002 ENGINE CUTTING OUT INTERMITTANTLY
Not sure if you have already figured this out- or just sold your car, but I have been having the same problem and had a bit of a search around forums etc. Looks like it is the Crank Angle Sensor which needs to be replaced. I am about to go and get my car fixed so fingers crossed this is the miracle cure. Here is a link to the forum discussion on the issue.
http://www.suzuki-forums.com/suzuki-aerio-liana-forum/37277-suzuki-liana-2002-engine-stops-2.html
Jun 24, 2009 | Suzuki Liana Cars & Trucks
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
37 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
