Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sony KF42WE610 bulbs burn out in 1-2 months
I have a Sony KF42WE610 the bulb tends to blow out in 1-2 months . I think the fan is bad? The last time I replaced the bulb I noticed the plastic around where the bulb monuts into the cabinet was a little melted. I thought perhaps it was not getting enough air circulation as the TV is in a tight cabinet . I moved the top shelf up so the air could circulate but the bulb still blows out?
Thank you,Dave
  • davidh0111 Jan 05, 2009
    Thank you,
    I will try the board. Any ideas of a good parts dealer I can get the board from?
    -Thanks again, Dave
  • 679 Answers
There is a power dioad god dam, due to which bulb burnt out.
Thanks for using FixYa.
Posted on Jan 05, 2009
  • 10,594 Answers
Hi, Sony Support has solution for lamp door melted problem and it is free from Sony.
    Genius:
  • 1,550 Answers
Yes you are correct it is due to fan that your bulb is blowing . There is no proper vent for air flow causing this kind of problem .
  • Sony Master
  • 19,396 Answers
Ift is not the fan, it is either a short on the bulb socket, or the small high voltage board that powers the bulb is faulty and must be replaced.
  • Ginko
    Ginko Jan 05, 2009
    The bulb does not blow out because it is too hot in there, it either blows because there is a contact (short) in the connectors inside the bulb cage, or more likely because the board that powers the bulb ( a small power board that provides high voltage power to the bulb) , is faulty, and is giving bad voltage to the bulb.
  • Ginko
    Ginko Jan 05, 2009
Both Headlights are not working, just changed them a couple months ago, what could be the problem?
Because you have given absolutely no details I am forced to guess as to your situation. The big factors are, what type of bulb did you get, how often do drive and is your car new enough that the lights come on even during the day?
Super bright bulbs are nice but they tend to burn out faster than normal bulbs. They claim to be good for about a year. How Long Should Car Light Bulbs Last But for some reason, a lot of companies consider that the average car only gets used for 12,000 km per year. if you drive double that, your headlights may only last half as long. Is you headlights on all the time or do you do a lot of night driving, it all affects how long the lights last.
Maybe you should check out these
http://www.candlepowerinc.com/pdfs/LL_Headlamp.pdf
or this
https://www.powerbulbs.com/ca/product/philips-eco-vision-h7-car-headlight-bulbs
Mar 03, 2017 | Cars & Trucks
Bulb burned out in 1 month
Your lucky it lasted 1 month. The population thinks they are receiving inexpensive items from China. Instead they are cheap useless rubbish. You will find that anything from Asia costs half as much and only lasts 1 tenth of the time. DO THE MATHS PEOPLE WE ARE BEING RIPPED OFF. While Asia is getting rich.
Dec 08, 2013 | LC EPSON ELPLP68 / V13H010L68 Projector...
Sony KDS-XBR60 lamp burnout twice
I would suspect the ballast that powers the lamp may be bad.
It would be a good idea at this point to Call Sony customer service to see if this issue in this model is in their extensive data base of problems/answers by model number.
Apr 05, 2012 | Televison & Video
Keeps blowing bulbs. Last one lasted 17 days
check the ballast leads which enter the rear of the lamp compartmnent they can tend to get pushed in slightly and prevent a good connection to the lamp. If the connections all look good then the lamp driver (ballast) is most likely defective
Mar 11, 2012 | Mitsubishi WD-65733 65" HDTV
After replacing a bulb, when power on, it flash first green and goes to flash red continue to flashes red about 5 flash each time what should i do?
5 is a lamp driver fault, could be a poorly seated bulb or a bad ballast. Usaly it is a bad ballast. Previous bulb failure could have dammaged the balast.
May 07, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Bulb keeps burning out
There are several reasons for short lamp life. Inadequate ventilation or clogged cooling fans, a bad lamp driver or lamp ballast (they are the same) and the use of non-original Sony lamps, as the aftermarket replacements are known problem causers. Remember too that the number of times the lamp is turned on and off is a BIG factor in how long the lamp will last.
Nov 13, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Ceiling fan light bulbs rouotinely burn out in less than 4 hours of use
"The only things I know of that cause bulbs to blow are, defective product, has been used its average life span, over voltage, heat and vibration.
The implication is that this has happened repeatedly so defective product is unlikely.
If it had lasted its normal life span you would not be asking the question.
Over voltage is out because the switch is off.
Heat is out because the the bulb is not burning when it blows.
That leaves vibration. Some types of candelabrum bulbs seem to quite sensitive.
What's above the ceiling The tink you hear is the filament breaking This most often happens when the bulb is hot. Very unusual to break when cold unless dropped or mistreated.
Don't see a fire hazard because switch is off."
Mar 14, 2008 | Hampton Bay 52 In. Black Huntington III...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
64 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
