Question about Frigidaire Affinity FASE7073LW
Dryer busing will not start - Frigidaire Affinity FASE7073LW
    Top Expert:
  • Frigidaire A... Master
  • 9,472 Answers
I think I also posted to your question about the dryer not starting. If the dryer tries to start and the motor is humming, you will need to check to see if there is something holding back the dryer from starting. Check around the motor to see if there is a dryer sheet or something else hung up in the motor. Also, check inside the blower for an article of clothing or something else jamming it up. If that is all clear, then the motor is bad and will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
How can you hire buses in Munich?
There are many Bus Service Munich available to hire. You can also visit some of the websites to find out the details. According to me, one of the best site where you can get all the details and that is Irro Reisen. You can use bus services for many purposes.
Nov 16, 2017 | Cars & Trucks
I have a creda tumble dryer and its not heating up i replaced the heating element but it's still not heating up
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in?Check for blown fuses or tripped circuit breakers--your dryer uses twofuses or circuit breakers. The dryer could tumble but not heat if onlyone of the two fuses is blown. If you have circuit breakers, one of thetwo circuit breakers can trip, even if the two for the dryer areconnected.
Heating element Oftena dryer heating element burns out, but doesn't trip the circuit breakeror blow a fuse. The heating element is simply a long coil of specialwire. You can check it for continuity with an ohm meter. No continuitymeans the element is bad and you need to replace it--electric heatingelements aren't repairable.
Thermal fuse Onmany dryers, there's a thermal fuse mounted to the exhaust duct insidethe back cover panel. The fuse--which is about an inch long--is usuallyembedded in black resin and mounted in a white plastic housing. If thefuse has blown, you need to replace it. (You can't re-set it.)
Wiring Acommon problem is for the main wiring connection from the house, at thedryer, to burn and break its connection. Because the dryer can stilltumble with partial power, the connection may be only partiallydefective. You may need to replace both the power cord to the dryer andthe terminal block inside the dryer that the wire is attached to.
Sep 02, 2008 | Dryers
How does the retarder work on tour buses in europe
The "retarder" is simply the use of the torque converter in the transmission drive assembly also has reverse fins with forward fins to slow the vehicle when driver releases the throttle, kind of like down shifting. It's just a little more direct.
Sep 25, 2014 | Cars & Trucks
What are buses when talking about network cards?
The paths taken by data moving with a computer are called "buses". Multiple side-by-side paths force data to move in parallel, and not in series (one after another).
Feb 14, 2013 | Computers & Internet
Our amana gas dryer. runs for about 20 mins and shuts off. try to resart and there is busing noisefrom the controls on top. if sets for 45mins. it will start again. until it gets hot. and then wont work.
The problem is in the gas valve coils. They sit on the top of the gas valves. When these coils are energized open the gas valves and allowing the gas to burn. If one or more coil malfunctions, the dryer shuts off. It is usually difficult to properly test the coils and replacement is the best solution.
Sep 25, 2009 | Amana Dryers
Maytag dryer MDE9316AYW - while running makes a high pitch noise. Becomes softer as clothes get dryer. I assume this is because of the load becoming lighter.
This sounds like motor and/or roller bearing/busings squeaking.
Remove front and lubricate all shafts/bearings/bushings in the belt path.
Here's some info on how to get it open.
http://www.fixya.com/support/t1466561-get_top_off_maytag_dryer_see_belt
Charile
Aug 22, 2009 | Maytag Dryers
Dryer wont work
I'm assuming that the dryer is gas, since both the washer and dryer are on the "same" breaker. I'd try replacing the wall plug before replacing the dryer. If you have a voltage tester, you should see if you are getting an honest 110 volts coming off the circuit. Since the circuit was a problem before, I would test it first and then more on.
Jun 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Wiring a 3 wire dryer wire into panel box
Stick her under the neutral buse, the groung and the neutral are connect at the panel anyway.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
BUSEFUL Backup
The bUSEFUL Backup Plus Folder located in the Internal Disk of the Mobile Pro 900 contains a CAB file named Backup_NEC.Arm.Cab. This file is not marked read only and being a Windows CE application , it will delete itself after installing the application. To obtain another copy of the Bsquare Installation file, please locate this file on the included CD-Rom and replace the one in the Internal Disk as necessary.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Frigidaire Affinity FASE7073LW Logo
54 people viewed this question
Top Frigidaire Affinity Dryers Experts
Are you a Frigidaire Affinity Dryer Expert? Answer questions, earn points and help others
