Rca washing machine XQ-606 continually fills with water on any wash cycle
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You need to replace the water inlet valve.
Posted on Nov 09, 2012
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
yalmer
  • 549 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    jsrock516
    • 5911 Answers
    SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
    Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
    http://www.fixya.com/support/r587481-prevent_washer_siphoning
    This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
    I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
    Posted on Sep 11, 2008
    SOURCE: GE SpaceMaker washing machine does not stop filling.
    try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
    Posted on Mar 27, 2009
    I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
    Maytag & Whirlpool washer diagnostic - Fills with water then ...
    ? 3:03
    https://www.youtube.com/watch?v=71zySSScDPE
    Jul 11, 2013 - Uploaded by ApplianceVideo.com
    Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
    Maytag top loading washing machine stopped working & filled with
    Dec 02, 2015 | Maytag MAV5920E Top Load Washer
    My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
    Sounds like the lid safety switch is either out of adjustment, or needs replacement.
    Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
    Oct 01, 2013 | Whirlpool Washing Machines
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Washing machine continues to fill when starts
    If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
    Oct 01, 2009 | Washing Machines
    Water inlet not filling
    check it has drained completely after the last cycle.
    if that is ok, take top off and check continuity thro the inlet valve coils
    Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
    Water continues to fill machine but the wash cycle never begins
    The pressure switch is stuck and not sensing the correct amount of water
    Aug 04, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Simpson esprit washing machine
    put a new pressure switch in it
    Mar 25, 2008 | Washing Machines
    Maytag washer PAV2300 water over flow
    from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
    Feb 21, 2008 | Washing Machines
    Washing Machines Logo
    41 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
