Question about BenQ FP71E 17" LCD Monitor
Benq FP71E, No Image Displayed
Suddenly, the Monitor does not works as with DVI connector as with VGA connector. It turns up, shows BenQ logo and then shows a white screen. I got a pic: http://flickcabin.com/public/view/full/17532
I am using an Nvidia 8800 GS with an FP17E Display and a Hannspree XV monitor, only the second monitor is showing images...
Thanks for any support!
    Sergeant:
  • 367 Answers
Try checking the settings in properties for this device to make sure they are as you left them. YOu can also uninstall the drivers for the card and reinstall them to see if that takes care of the issue.
Posted on Jan 05, 2009
Have connectd benq fp71e moniter it works good but no sound from moniter speakers
Try on putting a headphone jack similar to the the image:
Put it on back of your monitor's audio slot. It is usually colored green and then put the other end to your computer audio slot. Thank you
Sep 16, 2011 | BenQ FP71E
How to get sound working on a Benq 17" FP71E?
is on the back audio input connector, and you can set audio levels on the monitor menu items.
Nov 06, 2010 | BenQ FP71E 17" LCD Monitor
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | BenQ FP71E 17" LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
BenQ FP71E turns off after 2 secs- Logo flashes then turns off
LCD monitors behaving in this fashion more than likely have a faulty inverter. Refer www.lcdparts.net for solutions.
Sep 13, 2009 | BenQ FP71E 17" LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP71E doesn´t gives video
This suggests there is a dry joint on on the printed circuit board. I would go over with a soldering iron on all joints that look suspect.
Jun 02, 2008 | BenQ FP71G 17" LCD Monitor
My benq lcd fp71e 17"
ive solved this by taking out my vga cable and plug in my dvi cable and ive done some settings on my ati control center i have x1300 512 mb all you need is change your settings that this lcd dont support plus this monitor is huge!!!!!!!!! thank you for your support lol
Mar 29, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
452 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
