Blutooth lost i was about to send pictures thru blutooth but it didn't work
    Sergeant:
  • 286 Answers
Check do your bluetooth is jst receiver or trans/receive both.
Posted on Nov 08, 2012
How do I connect wireless headphones to my sony kv34hs510
Are your headphones blutooth or infra-red? Is your Trinitron Blutooth or infrared enabled to allow you to listen to it thru your headphones? If so, there must be an on/off switch that would actuate the Blutooth or infrared meachanism on the Trinitron itself. Otherwise, you WON'T be able to hear sound.
Sep 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Tip
WORX battery chargers
I'm going thru same prob. with 24V battery for WG167. Had same thing with older 18V that came precharged & then wouldn't recharge. 3 batteries later, they sent me to a "technical" rep who said "NO NO, it's not the batteries, it's the charger" He sent me a reconditioned charger & it worked fine. I'm not having any luck so far with the "MAX 24V". On my 2nd battery. It didn't come precharged & will only charge to 18V which is what the charger is outputting! Trying to get a "tech rep" to diagnose but no luck so far. Their tools are handy & work well if you can just get the battery/charger resolved!!!
on Sep 20, 2013 | Worx 10" 24v Cordless Li-ion Trimmer/edger...
How can i send a pictures or songs using my blutooth in my i-mate JAQ3?
have you enabled both devices' bluetooth and paired them?
Aug 22, 2012 | HP Computers & Internet
Trying to install Bible Navigator, using windows 7 and it won't load corrrectly. Is it compatible with Windows 7?
have you tried to install it thru the add & remove program in the control panel?
if you have & it didn't work -- try this---
go to my computer
go to the drive it's in
right click on the drive
click on explore
look for a setup or install icon & click on it & see if it will install that way
I had to install windows7 upgrade this way on my laptop
good luck
Sep 11, 2011 | Csdc Bible Navigator - Lifeway Christian...
05 tc. A/C blows hot then cold. Didn't blow cold
The A/C pump ismade of three seperate components. You are correct in it being electrical, to some degree. The compressor is self turnes, & in turning moves the freon thru the condensor,dryer, evaporator, & condensor. With the engine off, you can grab the clutch on the compressor, & turn it manually. Now, to your question. When you turn on your A/C, it sends a signal to one of 3 parts on your A/C compressor. The 1st signal, is a charge to the magnet (not its nomenclature name) that pulls the clutch, quickly, into the compressor shaft, so it can start turning. Now as this signal, is working,on an intermittant basis, 1 your clutch has been damaged, not always engaging fully,causing disc wear. The activating magnet, works intermittantly, this too, strains the electrical wiring, going thru the compressor to the magnet. Now the compressor works, but, 2 components, have gotten very hot, by intermittant action. To remove them, if "fused", will be labor intensive. Thanhaving a "sealed" system, dis-assembled, then re-assembled on a mechanics work table. No matter how hard I try its never completely clean......the repaired compressor can allow harmful contaminates into a system that works, with one part not working. Once contaminates are in the system......all the components can be damaged. The mechanic, is giving you the most cost efficieant repair, that will last longest, with least possiblility of failure.
Aug 31, 2011 | 2005 Scion tC
Jabra extreme headset. Lost my manual. will the headset also work with my IBM thinkpad computer?
Should work with an blutooth equipment that you own. All you'll need to do is pair them. This can be done from your thinkpad (if it has blutooth?) in the settings menu by following the onscreen instructions.
Thanks
Moza805
Aug 30, 2011 | Cell Phones
I didn't get an installation manual with my unit can you send me one or can you email to me? FRA052XT7 5000 BTU Chesagrey@gmail.com
There are 2 manual you'll need, The Installation Manual and the Owners Manual.
Installation Manual http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020211A0669en.pdf
Owner's Manual http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020211A0657en.pdf
You can download and print each one for future reference.
Hope this helped you & thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
I purchased a new mobile on friday ..LG GN360 touch mobile. I can not get the mobile to recognise the polaroid pogo, even though i have used both sets of instructions from mobile & pogo. ie: switching...
I do not have the LG touch mobile, but experienced a similar problem with another device. It didn't work at al: I selected a photo, say print and sent it via bluetooth to the POGO, it didn't connect.
The solution that worked was: Not give a PRINT-command! Just SEND your picture to the POGO by bluetooth, and it will start printing.
Jul 17, 2011 | Polaroid PoGo Digital Photo Printer
I did not get the picture of the printer cartridges, I lost are session.
Hello!
Found your question by accident. I wondered why you disconnected? You didn't get the page I sent via email? If you still need help with this problem. download AIM (america online instant messager) register and get a user name - sign in and send me an IM to kndkcook - and we can use that chat box to finish troubleshooting your problem.
Jul 12, 2011 | Office Equipment & Supplies
BLUTOOTH MALFUNCTION, UNFUNCTIONAL
My phone did not receive any transactions from the other mobile phone thru bluetooth.
Oct 21, 2007 | Sony Ericsson P900
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
