Question about Water Heaters
I have a Ariston combi boiler and the mechanical clock doesn't keep time. Means heating can not be put on timer. Please help!
  • 17 Answers
SOURCE: Ariston Combi euro boiler SX20 MFFICE 970903039 GC No 4711602
have you tried to put some cleaner into the system it siounds like you may have a circulation problem
Posted on Nov 27, 2008
tborn6
  • 700 Answers
SOURCE: Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Posted on Jan 11, 2009
  • 68 Answers
SOURCE: boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Posted on Jan 14, 2009
  • 150 Answers
SOURCE: combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Posted on May 03, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Vaillant boiler clock not working
your timer clock may need to be replaced.
Aug 12, 2017 | Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
Boiler problems
Jan 11, 2009 | Water Heaters
Nov 27, 2008 | Water Heaters
Water Heaters Logo
560 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
