Question about Datalogic Dragon M101 (902201780) Portable Terminal
Keyboard Issue We have an issue where the keyboard on a PC connected via a Datalogic Dragon M101 hand scanner, keeps beeping and sporadically missing out letters. When the keyboard is plugged directly into the PC, there is no problem, however as soon as the scanner is included, the problem starts again. The keyboard has also been changed. Is there any solution for this, or does this indicate a faulty scanner or cable? Thanks very much, Kelly
  • ROBERTO
    ROBERTO May 11, 2010
    tell me the problem
2 Suggested Answers
rdiodoro
  • 13 Answers
SOURCE: Datalogic Dragon M101 postamble CR to HT change
hello Jimmy
Download "VISUAL SETUP 4.1" and do anything you want
give me a answer.
Regard
Roberto
Posted on Dec 17, 2008
M101 keyboard replace
Keyboards are usually screwed in on the top of the laptop as well. Try to pop off the plastic cover above the keyboard, there should be little slots to allow you to take it off. Then there should be some screws under there for the keyboard.
Aug 02, 2012 | Advent Modena M101
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
Cant connect old dragon m101 to computer
Hello Community,
as I see there are many questions still unsolved to this older product series. You can get the Quick Reference / Kurzanleitung here.
Don't hasitate to contact me, if you have further questions.
Regards ...
Sep 14, 2011 | Datalogic Dragon M101 (902201780) Portable...
I have datalogic memor scanner. i can't connect to Windows mobile device center in Windows7. also it's driver does not work
Dear Original Asker,
Unfortunately, the older Datalogic Memor devices, which I believe your model is by the issue; model (Windows CE 6.x), can't support, and doesn't have drivers that work with Windows 7. You need Windows 6 (Vista) to use the device. In other words: all software support for the device with that firmware was dropped with the advent of Windows 7.
Solution: Update the firmware on the Memor via a Windows Vista PC, then connect the device to a Windows 7 PC.
Nathaniel Sherman
STLCC - 2012 Mathematics
MS&T - 2014 BS-CE/EE
Oct 10, 2010 | Datalogic Memor Smartphone
I need an owners manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
If your cables are connected between your keyboard and PC, be sure to set up the correct Keyboard Wedge Parameters, beginning on Page 34, to allow connectivity.
I'd start by scannig barcodes "CE" and "ZA" to reset to default wedge values. If that doesn't work, I'd procede to sc an "CF" for PC=AT,PS/2.
Pages 36 & 37 address the Caps Lock issue, where the scanned value is in the wrong upper or lower case.
Have a nice day,
Label_Guy
Jun 12, 2008 | PSC Quickscan GP5385 Handheld
hello Jimmy
give me a answer.
Regard
Roberto
Mar 05, 2008 | Datalogic Dragon M101 (902201780) Portable...
RE: Tea spilled on Toshiba Qosmio G15 Keyboard
Simple swap! You need to turn over the PC, Locate all of the screws on the back, most of them will be identified by a circle with a K in the middle for Keyboard. Unscrew all of those screws, becertain to get them all. Once you have done that make certain to carefully remove the keyboard. The keyboard is attached to one connection that snaps into the mother board so do not pull too hard on the keyboard! It is that simple!
Nov 25, 2007 | Toshiba Qosmio G15 Notebook
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
Keyboard does not work when I connect my scanner
council to put an adapter usb/ keyboard and solve, or you need to change in Setting
Nov 22, 2006 | Datalogic Lynx D402 Scanners
Datalogic Dragon M101 (902201780) Portable Terminal Logo
67 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
 Ian Kayhan
Ian Kayhan
ray gallant
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
