Question about Dell (Inspiron 531) PC Desktop
On starting pc, I get message files: windows/sytem32/config/ error: 0xc000000f files missing or corrupt cannot do anything, not even safe mode, any suggestions please
  • 130 Answers
If the computer came with and Windows CD you can boot that up, and then run the repair console (press r) and then try running chkdsk /r at the c: prompt
Posted on Nov 08, 2012
5 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: My Dell Desktop cannot start in Safe Mode
hi there,
you mention you have change your hardisk,you have to check if your hardisk was configure in cmos and bios set up, first whaen you start your computer press F2 then bios set up appear,check your device if
was connected on your system.on main menu check your ram if it was connectd,then press arrow right to advanced menu check your hardisk from IDE configuration if both hardisk and memory was installed or cofigured by your system.go to boot menu to set your device, on boot menu,scroll it from boot device priority
if you assure there is windows installed already on your hardisk,priority your hardisk,second your cd room,third floopy etc.press F10 to save and restart your computer,If no sytem was appears you must reinstalled your windows but you should change again
the boot set by priority the cd room instead of hardisk in order to put windows on your computer.press F10 again to save and restart your computer
to install your windows
insert windows cd on cd room
wait to configure your computer by the cd windows
then ff the windows installation procedure
until windows installation was finish.have a nice day don't forget to rate me please.thank you
Posted on Feb 21, 2010
Testimonial: "Helpful advice, quite thorough but not sufficient as the problem is not yet resolved. Perhaps I need to better explain to the Guru and will do that."
melnavz
  • 1226 Answers
SOURCE: Problem booting up dell dimension 2300 desktop.
You have no choice either you should reinstall your system, you should provide windows CD/DVD installation and boot your system using this disk.
However; you should backup your important files be cause most likely the all files will be removed during the installation process.
Posted on Jan 04, 2008
pferd
  • 94 Answers
SOURCE: not starting up
use the recovery CD to start, maybe it can fix the issue as well.
WARNING: Do NOT allow it to replace the information without backing up, it could set it to factory 'zero'
Posted on May 08, 2009
  • 12 Answers
SOURCE: following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Posted on Dec 31, 2011
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
Error message corrupt file or missing
hi, the best thing to do here is press f8 on start-up, you will then be greeted with a number of options select safe mode ,and then select System restore, hopeful it was turned on so you can step back before Angry birds was downloaded, you will need to press f8 a couple of times straight after the bios display on the screen...
Regards
Dec 21, 2012 | Sony VAIO Computers & Internet
Im on my pc and im wondering where i can find a free download that can help me i get this message on my toshiba satellite a85s107... File missing or corrupt: \windows\system32\config\system\
Assuming you already tried pressing F8 on boot up and trying to get it into safe mode to run a disc check and that did not work?
This is a configuration file that can only be repaired by the use of OS installation CD, which if the laptop is booted with the disc in the drive and the bios is sett o boot from the DVD drive first, will give you the option to carry out a repair of the installation
Jun 21, 2012 | Toshiba Satellite A85-S107 PC Notebook
It won't load windows! windows won't start because the following file is missing or corrupt. windows\system32\config\system.
try starting in safe mode by pressing f8 key on system boot ,
looks like you may have hdd problem, if you get message 0disks filling the screen hdd needs replacing
Feb 22, 2011 | Aspire Acer AS5315-2856 Laptop
Unable to boot PC
link to external sources to help you stay safe (Avoid Internet fraud! ... must have an anti-spam filter that can block spam in double-byte ... But a little caution can go a long way towards avoiding malware exposure. ...... Windows 2000 server could not start because the following file is missing or corrupt: ...
Jul 13, 2010 | Dell Dimension 9100 PC Desktop
A FILE WINDOWS SYSTEM ROOT 32 IS MISSING OR CORRUPT
Try starting in 'SAFE MODE'.
Click START
Click RUN
Type CMD and press ENTER.
Type 'CHKDSK C: /F' and press ENTER.
If you are prompted to shutdown & restart to run the "check disk", do so.
During the restart, "check disk" will find/repair any file-system problems, and then restart in "normal" mode.
Sep 18, 2009 | Compaq Presario 5000 PC Desktop
Missing or corrupt file
See if you can go into setup by pressing the F8 key when you first turn on the laptop. It should bring you into a menu, if it does then choose safe mode. If you can get into safe mode then do a system restore back to a date when the laptop was last working properly.
If you can't get into safe mode then your system files are corrupt and you'll need to reset the laptop back to factory default and I believe it can be done by pressing F11 when you first turn on the laptop assuming the partition with the info on it is still there.
If you can't do this then you'll need to find the cd's that came with the laptop and install the operating system first and then the drivers and applications cd.
Let me know if I can be further assistance.
Ben
May 18, 2009 | Compaq Presario V4000 Notebook
Clevo 900K, Crash: c\windows\system32\config\system - file is missing or corrupt. Insert original setup CD and press r for repair. I don't have original CD. System won't restart even in safe mode or d
to setup a new windows installation or repair an old one you do need an installation cd, for it, no other way i am afraid,
ask for safecopies from a friend, maybe
Apr 21, 2009 | Computers & Internet
\windows\system32\config\system missing or corrupt
You can do a refresh of your Windows OS, if you have Windows XP. You need to boot to your XP CD and do a repair. This will only restore the Windows OS files and you will not lose your personal data.
This should help. please rate my response.
Feb 17, 2009 | Gateway MX6440 Notebook
Dell (Inspiron 531) PC Desktop Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
