Question about RCA P61927 61" Rear Projection Television
61" RCA Screen Protector Cracked
My 61 in RCA Projection TV outer protective screen cracked and needs to be replaced, can't find the replacement screen anywhere. The model # is P61927. Can you help me?
  • Anonymous Jan 25, 2009
    i have the same problem. Did you fid a replacement?
  • pinner1685 Jan 26, 2009
    NO I have not found a replacement
BenjaminaBOY
  • 18 Answers
SOURCE: RCA P61927 61 in Rear Projection Television
It might be that you left it on SO long the 'Light wires' that make the screen show stuff on it, is worn out I would suggest replacing them, or not using it for a week.
Posted on May 29, 2007
techman
  • 3130 Answers
SOURCE: Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Posted on Oct 16, 2007
SOURCE: toshiba 50a60 cracked screen
i have just experienced the same myself, what you need to do is find a tv the same size, it doesnt have to be the from the same manufacturer, although it helps if you can get the same, as all lenticulars do the same job.
The outer screen is called the Lenticular, and the inner is called the fresnal, depending how bad your lenticular is cracked will determine if your fresnal has gone also, the only real way of knowing is when you take it apart to change it, (Dead Easy).
they are quite close together, but dont be afraid of trying, i have never changed one before, but i did it in about forty minutes and i dont know the first thing about tvs and now it is as new.
to change it, all you have to do is unscrew the front of your tv, from the surrounding screws at the back of it, once you have done this there are four or five small screws that hold the front of it up, take these out and your front will come off complete with lenticular and fresnal.
place it face down on a soft surface, so as that you are looking out of the inside of your screen, and you will see the fresnal.
they are held together with four brackets, one on each side of the screen.
unscrew the brackets, and take the fresnal off, then the lenticular.
put your new lenticular in, then the fresnal on top of that, and then secure it together again by screwing the four brackets back on.
it really is that simple, do not let these TV repairmen, scare you into buying a screen from them and charge you an extortionate amount of money to fit it.
im not sure if plexiglass will work, i was quoted £160+VAT for my screen from Toshiba, so what i did, i went on Ebay and found a full tv that was for spares or repairs, and paid £26 for it, and it is just as it was before.
One thing you must not do when attemting to change it, and that is to be scared of attempting it, because once you have done it, and at a fraction of the cost, you like me will curse the people who make a living out of overcharging people for such an easy job!!!!
Good Luck, and hope this has helped..
Doolb
Posted on Nov 13, 2007
TOM2-TOM2
  • 110 Answers
SOURCE: cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Posted on Jun 10, 2009
SOURCE: Cracked Screen Protector
where can i find protector screen for my 52" magnovox screen
Posted on Jan 13, 2010
what is the model number for you set. is it a hd52w56 or something like that. on that model it is called the super sheild. is the inner screens damaged.. if just the outer screen that runs 200 or more. i have seen people just replace the plexiglass on it. the inner screens run about 250
Nov 09, 2008 | Televison & Video
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cracked screen
The lenticular and fresnal screen for that unit are sold together under RCA p/n# 258513 and are available from Vance Baldwin for about $260.00 plus shipping.. They make for an oversized item so the shipping is probably 70% of the part cost.
www.vancebaldwin.com
Hope this helps!
Bill
Dec 07, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
my son cracked our screen protector and instead of paying two or three hundred dollars to replace it we had plexy glass cut at Lowes and put velcro striping around the edges and looked as good as the original and has held up great for five years now.
Oct 26, 2007 | RCA P52937 52" Rear Projection Television
My tv
if your tv has black borderaround screen protector it has to be replaced with original part..if not it can be replaced with plexi-glass, avail at local home improvment stores john
May 24, 2007 | RCA P52926 52" Rear Projection Television
I need the screen for this tv can you help my son crack it
I think that Thomson is the manufacturer or distributor for RCA parts, keep that it mind when looking for your screen. you might be able to get it at vancebaldwin.com good luck
Nov 28, 2005 | RCA P61927 61" Rear Projection Television
RCA P61927 61" Rear Projection Television Logo
185 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
