Question about Measuring Tools & Sensors
Rapitest dm10 user manual - Measuring Tools & Sensors
Duracell MN21 can be found in most big supermarkets
Posted on Jul 29, 2014
What battery is required
Posted on May 26, 2013
How to use rapitest pt112 power tester?
Go on the net and get the manual on a download from axminster.com
Jun 15, 2014 | Cars & Trucks
Rapitest digital plus moisture meter manual
www.lusterleaf.com/img/instruction/1825_instruction.pdf
May 23, 2014 | Measuring Tools & Sensors
I have a dm10 and I keep getting
UNPLUG A TRIGGER. PLUG BACK IN AND HIT O.K.
Sep 29, 2012 | Alesis DM10 (Module) High Definition Drum...
I want to change a plug socket, and know that I need to turn of the elictricity at the mains, and check the wires with a volt checker to check for live current. I bought a Rapitest digital mini electrical...
Yes you can use this instrument to measure. It needs to be put on the AC voltage and to be on the highest value. Voltage is measured with a fuse included (be careful). It is better to use a screwdriver tester to find a phase (hot wire). Wires are measured ohmic and should not be turned voltage on(or it may burn the instrument). If you measure current it can short circuit if the installation is under voltage (because of this reason the current is measured in series connection).
Sep 01, 2011 | Measuring Tools & Sensors
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
What is the sonin rapitest power sensor? I have one but do not know what it is for. Thanks. tk
Sonin Rapitest power sensor will identify live electric wires within your walls. Mine quite working this weekend. lwf5990@frontier.com
Feb 02, 2011 | Garden
Online manual for Rapitest Wps 115 Wire/Pipe & Stud Detector
go to the support center for the maunfacture site
Oct 13, 2009 | Hand Tools
Electrical cables are all black & I need to find which is live &
ac, aka, alternating current, is the type found in your house. dc, aka, direct current, is the type found found in your car...or any other type of battery. If you have a total of three wires, one green, (ground) and the other two are black, then the two black wires are your alternating current wires. If this is the case, hook up your black wire from the fan and light to one of the black wires, and the whites, or commons, to the other black wire. In alternating current it does not matter which wire goes to where.
If there are 3 black wires, and a ground wire, then you will have to use your volt meter, and check the voltage from the wires, you should take three readings (wire a-b, wire b-c, and wire a-c) two readings will give you 120 volts and the third will give you 240 volts (approx) The two wires that give you 240 are your hot leads, and are probably controlled seperatly by wall switches. Hope this helps.
Jun 22, 2009 | Dryers
Measuring Tools & Sensors Logo
1,063 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
