What is the main causes tn damage CPU - Computers & Internet
  • 7,627 Answers
HEAT
Posted on Nov 08, 2012
Error code sc 680
Refer to BCU/MUSIC communication error.After the engine CPU sends a message,the MUSIC CPU does not respond within five seconds three consecutive times.
Possible cause:toner cartridge memory chip loose connection,memory chip problem,memory chip cable wiring problem.
Turn the main switch OFF/ON.Check if the toner cartridge is installed correctly,replace the toner cartridge,check the harnessess are not damage or replace BCU board.
Feb 14, 2013 | Ricoh Aficio 2232C Color Copier
Cpu not heating, ite chip getting very hot ,no display
If the fan on top of CPU is dirty, dusty, damaged or not connected properly,it could cause CPU to overheat. The Computer should switch off automatically to prevent damage to CPU (they can burn out very quickly if not cooled properly!!!)
1. Is the fan connected properly to motherboard?
Check cable running from fan
2. Is fan dirty or dusty?
Use a small brush or can of compressed air to remove dust off fan. Never use a normal household vacumn cleaner-this can create a static electric discharge which could damage components.
3. Is fan damaged ie does it spin when powered on?
Replace fan with similar make and model
Hope this helps. Thanks for using Fixya
Jul 13, 2011 | Computers & Internet
I have XP SP-2 operating system, 2 GB RAM Ausus Motherboard. My system retarts automatically after 5-6 minutes particularly during media player. I have updated my media player and even with update of media...
Media/ Gaming etc consumes more CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming
and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module).
Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | ASUS P5LD2-VM Motherboard
Tv seems to only have red and green colors
SOLUTION: Set "Option Data" and "Model ID Data" after replacement of the Main TN / AV Signal
PCB for then model being serviced. Refer to Service Instruction INST2007-040 Rev 1 after
replacement of the Main TN / AV Signal PCB
Dec 28, 2010 | Toshiba 42HL67 42 in. LCD Television
Power light comes on, wireless lamp is on, fan runs. will not boot screen is black. function&F2 will not toggle wireless no HD or CD activity
Try reseating the memory / booting with only 1 stick and NO battery just AC adapter.
What happens?
Try with the hard drive and optical drive out too if the above changes nothing.
Let me know what happens...
Oct 28, 2010 | Gateway M-6827 Notebook
Why my processor get damage and also burn the 9T15GH transistor? what is the cause?
It is related to your V-Core circuitry problem. Check VDD ADP3181/3180 and driver ADP3418K/J. Some versions having Protection diode short parallel to V-Core pad ....
Oct 02, 2010 | ASUS P5PE-VM Motherboard
My computer turns off and on again for a few seconds. (this time it will bootup) when i pressed the power button. i already change the ram to 1gb but the problem still occurs. What can i do to fix this...
It may be owe to software problem 1, the virus "shock" virus attack will prompt system will automatically start in few seconds. From the remote control you Trojan program all the activities of the computer, including let your computer restarts. Remove viruses, trojans, or reshipment system. 2, the system files damage system files destroyed, as the KERNEL32. Win2K DLL Win98 features, the font list below such basic execution system files destroyed at startup, system will therefore cannot finish initializing and forced the restart. Solution: cover installation or reinstall it. Hardware problem: 1.Chassis power is not enough, dc output is pure, the dynamic response sluggish. Users often ignored or assembling businessman, using cheap price of power supply, so is the largest system of automatic restart suspicion. (1) the power output power shortage, when run large 3D gaming occupy CPU resource of software, the CPU needs power supply, power is not caused by overload protection, stop the power output. After the output power to stop, load, reduce power restart. Due to the protection of the recovery/time is short, so we are hosting automatic restart. (2) power dc output is pure, pure dc power supply of digital circuit requirements, when the power output of too direct, the harmonic content will result in digital circuits, performance is often work to crash or restart. (3) working load of the CPU is dynamic, on the current requirement is dynamic, and the dynamic response speed quickly. Request Some of the poor quality power dynamic response for a long time, could also lead to crash or frequent restart. (4) high-end graphics update equipment (large disk/video card/equipment (increased), after the hard disk) / burners, power supply of original beyond rated output power will cause the regular crash or restart. Solution: now in high quality high-power computer power. 2.The memory chip thermal stability, incorrect or damage to restart the system memory problems to restart the system of risk. (1) the poor thermal stability of memory, boot can work normally, when the memory to a certain temperature, temperature is can not work normally, which leads to crash or restart. (2) memory chips, slightly damaged, also can pass on self into the system, when the operation can be some big software throughput will restart or crash. Solution: replace memory. (3) memory of CAS value too small can also lead to instability caused by system memory, automatic restart. General had better use the default Settings, don't roll change yourself. 4.The CPU temperature exorbitant or the cache damage (1) the CPU temperature exorbitant often causes protective automatic restart. The basic reason of high temperature is due to poor cooling chassis, CPU, the CPU is undesirable reasons: the heat radiator thermal conductivity low, radiator material with a foreign body between CPU interface (1) for quality assurance, fan speed is low, the fan and radiator dust too much, etc. And P2, P3 motherboard CPU temperature probe damaged under the mp4 or within the CPU temperature detection circuit on the mainboard damage, the BIOS BUG in a special conditions of temperature, the CPU CMOS setup to protect low temperature, etc. Can also cause protective restart. (2) of an internal CPU, level 2 cache damage is CPU common fault. The extent of damage, or can start, when running into the system, the software (some throughput big media player, games, 3D graphic) will restart or crash. Solution: in the CMOS setup of shield (L2) or level 2 cache cache (L1), 1 or replace the CPU. 4.AGP display, PCI CARDS (nics), cat restart automatically (1) the external card or poor quality work not standard, AGP/PCI bus signal misoperation cause system RESET to restart. (2) and graphics, loose network system may cause restart. 5.Parallel, USB access is serial, fault or the incompatibility of external devices restart automatically (1) the fault or not compatible with the parallel damage, such as printer, a foot of short-circuit, USB equipment damage of short circuit, signal level sutural definition, opaque, etc. (2) hot swaps external devices, shaking, cause signals or power instant short-circuit. 6.Mainboard failure In case of automatic restart motherboard is rare. Generally RESET circuit are associated with a fault, Socket weld is empty, slots, contact undesirable, Individual chip, capacitance elements such as damage.
Jun 23, 2010 | Acer Aspire 4315 Notebook
I puug tn cord the green light goes off wont
check if the power ac adapter pin the goes to the side of the laptop is damage, if not then try connecting ac adapter with laptop to a diff power wall socket, if fails then replace the motherboard.
Oct 12, 2009 | Dell Inspiron 1501 Notebook
92 fxr installing new regulator....which breaker is 30 amp?
30Amp breaker is the Main Circuit Breaker. The blk wire goes from the copper stud on it to the starter. The TN goes from it and splits, one tail goes to post A on the ignition switch and the other to the starter relay. Another BK wire goes from the same post as the TN wire and it goes to the regulator.
Aug 26, 2009 | 1993 Harley Davidson FXR Super Glide
Ei systems 4411 wont power on/mains or battery power
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
Oct 30, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
