Denon avr 1311 powers on then shuts off - Audio Players & Recorders
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: DENON AVR-1404 switch on problem
Maybe the audio amplifier IC´s are damaged that´s why go on the protection mode
Posted on Aug 22, 2008
SOURCE: Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Posted on Jan 10, 2010
  • 163 Answers
SOURCE: Denon AVR 2105 power shuts off,
The receiver has an internal problem like bad power supply or burnt channel. You need to bring it to a local repair shop or mail it here.
Posted on Feb 07, 2011
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
Denon avr 1311
This could be just a faulty headphone socket. Unless the headphone socket has a built in pre-amp stage.
Jun 01, 2013 | Audio Players & Recorders
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
Denon AVR 2105 power shuts off, tried resetting the micro processor and no luck. Please help...
Feb 06, 2011 | Denon AVR-2105 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
496 people viewed this question
 Grubhead
Grubhead
