2002 Land Rover Discovery Series II Logo
Nicky Posted on Nov 08, 2012
Why does my Land Rover Discovery air suspension drop very low to the driver's side back wheel but the passenger side suspension is perfect but when I start my Discovery up again it goes to normal
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
671
Points
Dear,,,you need to change air baloon, it might leaking.
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 02, 2010
SOURCE: is it possible to fit land rover discovery 2 wheel
is their any difference?? i would really need to get my hands on and around this to see whats what ,but i should think it could be done
Wayne Tolonen
  • 394 Answers
  • Posted on Feb 02, 2010
SOURCE: discovery has started to drop on wheels at the back
Well , Your rig has an air ride suspension. The fix may be simple. A loose air line. Expensive , The compressor, the air bags or control valve.
There is available an after-market non air suspension kit.
Sorry ---- other than the loose air lines it get's spendy. I do not know the prices.
Testimonial: "thanks! i had the land rover people look at it, which cost me alot thay want £1000 for the job conpleat change of the bags! having a look else! scott"
Anonymous
  • 16 Answers
  • Posted on Apr 02, 2010
SOURCE: blows cold air on driver side and...
blend motors
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Feb 14, 2012
SOURCE: 05 Range Rover HSE inactive air suspension
Sorry computer controlled and it needs the dealer software to find the fault ,lot of money i would imagine to repair in the dealers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on May 24, 2012
SOURCE: My 1999 land rover discovery won't start when I
Does the starter spin? Has the battery been load tested? Are the battery cables clean and tight on the the battery posts? Check all this and you will likely find one of them to be the problem.
2answers
Land rover discovery faults
May be a shock. Never heard this before but shocks fail in weird ways
2answers
Clunk from front of land rover discovery but only occassionally
have the vehicle put on a 2 post hoist that allows the suspension to drop right down
then carefully check the rubber insulators on the lower arms for splits or indications that the rubber is tearing from the metal bushes
I can't get my 95 Land Rover Discovery out of 4-wheel drive
The vehicle is all time four wheel drive, it cannot run in two wheel drive. The second shifter is for differential lock and high/low range selection.
3helpful
2001 land rover discovery II locate fuel filter and fuel pump
If you're standing looking at the rear of the vehicle, it's on the chassis rail on the right hand side rear wheel arch.
4helpful
Air suspension drops on one side
Common problem. You have a slow leak. Just like a tire, the solution is to look for it, with a spray bottle of soapy water. All the lines, fitting, valves, etc., are suspect. The actual chambers are the only expensive parts. There are leak stop liquids you can try?
1helpful
Discovery has started to drop on wheels at the back
2answers
My left said on my land rover dis drop and it
bring it to a dealer so they can hook it up to their computer to diag. it. ive worked on these before and there is a lot that could be wrong with the ace system
Disco 2 rear air suspension problem
listen for air leaking from the bag or the air supply line
Passenger wheel on drivers side lower
You may have damaged the suspension and or the wheel rim, i would suggest having the vehicle checked out before relying to much on it in hostile weather.
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
