My mpn1-11cr portable AC, when plugged in, hums for a few seconds but does not start up. central button lights up but control buttons do not respond. have tried various plugs to assure amperage is available. What to do?
KOakaKO
  • 135 Answers
SOURCE: Haier wall-unit AC wont work
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in. This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine! Couldn't hurt to try it out. ;)
Posted on Aug 04, 2007
techguru005
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Posted on Feb 22, 2008
NetSalem
  • 55 Answers
SOURCE: my asus d1500t wont startup
Most likelly your motherboard went bad, but you can try somthing else before replacing your MB.
1. Remove your battery and try to power up. Your battery might be shorted.
2. Remove your hard drive and try to power up.
3. Remove your CDROM and try to power up.
Good luck.
Posted on May 28, 2008
SOURCE: ps3 won't boot
The same thing happened today to mine so i rang sony. They said because i bought my ps3 when it came out as a good will gesture their sending a courier out to me to exchange it (In 2 days). Man I love Sony don't know about you guys. LOL.
Posted on Aug 05, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Aqualux Whirlpool Bath controls not responding
Unplug, every thing, take batteries out of remotes etc, remove power from all parts.I mean every parts. leave out for about a minute. reconnect all. try then
Dec 02, 2013 | Home
Aqualux whirlpool bath
The panel has failed and it is unlikely that it was your dogs fault.
Dec 02, 2013 | Washing Machines
Unit turns on but does not respond to commands.
take the cover off and locate the humming noise...is there a belt loose?
Nov 25, 2013 | Sony MegaStorage CDP-CX455 400-Disc CD...
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Wii won't turn on!!!
Try resetting the AC adapter.
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 03, 2009 | Nintendo Wii Console
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Can't start
Try removing the power adapter and battery. Then hold the power button in for up to 60 seconds to discharge the laptop.
Plug it back in and see if it will boot.
May 04, 2008 | Acer TravelMate 292ELMI Notebook
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
