Question about Garden
Hayter Harrier 56 will not start
The engine starter pull cord, when pulling the cord it pulls out for a little bit then gets stuck. Previously to that the lawnmower was working
rburroak
  • 14 Answers
SOURCE: starter cord only pulls 1 foot
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Posted on Jun 19, 2009
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
  • 70 Answers
SOURCE: How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Posted on Oct 04, 2009
  • 15 Answers
SOURCE: MTD Yard Machine CD000147 6HP 21 inch ..The
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Posted on Apr 19, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My Hayter Harrier 41 lawnmower starts but keeps
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
Cant remember how to start my g100 wacker. Can pull the starter cord but forget where the little knobs need to be turned to
I am not familiar with your model but general rules are as follows. 1 - make sure that the gas'oil mixture is the right ratio and that the fuel is not stale. 2 - Depress the little rubber primer bulb 4-6 times, or until yor see little bubbles through the bulb. 3 - Rotate the choke lever to Full and pull the starter cord until the engine tries to start. 4 - Rotate the chole lever to Half and pull the starter cord until the engine starts.5 - After the engine warms up, rotate the choke lever to Run or Open so that the engine runs smoothly.
Jul 01, 2011 | Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
I have a craftsman leaf blower model 335879770. The pull start doesn't engage. You can pull the cord and it recoils back but doesn't crank the engine. I have it apart but how do I get to the starter pulley...
you shouldn't have to there are little ears on the flywheel that the starter recoil hits when pulling the handle they might be stuck or not moving when pulling handle
Nov 09, 2009 | Garden
Starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Mar 22, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
