Question about Canon PC1061 Copier
How to remove the scanner unit on Canon PC1060
There is paper stuck inside the fuser on a Canon PC1060 copier. I have tried removing some of the jammed paper but there still some more that keeps making the machine jam. How do I remove the scanner unit to get to the fuser? Thanks in advance!
  • fmraynor Jan 05, 2009
    There is paper around the fuser roller. I thought I had to remove the fuser to remove the paper, but cant find a way to take it out...
  • Anonymous Mar 30, 2014
    would like to remove fuser unit
    Novelist:
  • 148 Answers
You sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
  • Steve Archer Jan 05, 2009
    Just a quick note paper can get scrunched up against the picking fingers on the fuser rollers very carefuly use tweezers or hemostats to pull the pieces out
    there is a wiper pad on fuser roller that should be removed and have few drops of fuser oil placed on to keep roler clean
    You can remove the paper from the fuser roller (wrapped around fuser roller
    FIX
    1 Open fuser area
    2 turn power offt
    3 there is usually a lever you can push tor take pressure off of the lower roller
    pres this lever and take a flat headed screwdrive and slide into the right end of the rollers(do not touch roller with any sharp object
    4 with the roller in the up position try to turn the top rollerwith your hands and also try to get your fingernail or a wooden shewer and dig the paper out the object is to get large pieces off of the roller
    5 if you are stil struggleing you have to remove the back cover off and remove the drive gear of of the fuser roller to back out the paper
    90% of the time I am able to dig the paper out you wil hear the roller chatter when you pull the paper out
    Do not use any metal objects because you can damage the roller
    Hope this helps
Paper is stuck under the thermal unit and cannot be removed. The unit probably has to be removed to get at the paper and we need instructions how.
First you must remove the cover for the duplexing drawer below the fuser drawer. It will allow you to fully extend the fuser drawer to remove the fuser unit. You have to remove the 3 front covers of the fuser drawer, remove the three black screws that secure the fuser motor, then the yellow cover to access then two screws that secure the fuser unit to the drawer. But you must unplug the connectors you see in front of the fuser unit. I believe there are 5 connectors that need to be unplugged. Don't forget to unplug the connector below the fuser unit. This is the sensor that tell the fuser shield its home position. You fully extend the drawer by looking at each side of the drawer and push in the leaf springs you see and pull the drawer out further. Remove the two screws you see on the top of the fuser and gently remove the fuser unit. Take your time and all should go well.
Jan 15, 2011 | Canon imageRUNNER 5570 Copier
Hello, we have a Canoncopier pc1060 with a paper jam. We need to be able to get the top off to remove the jam. we thought we got it all out from the side but we can hear a piece of paper in there when the...
I'm not sure if you mean the adf or the top half of the copier??? The adf comes off, it's tricky, there are pins that hold it in. As for the top part of the copier, why would you? I did it only once, will never do it again. I think you problem is in the fuser unit. If so, it comes out of the left side by the exit tray. Before I go any further, have you seen any small pieces of thin blackish grey plastic. If so, you need a new fuser unit or fusing film. I would not go any further if that is the problem. Without it to put right back in, you will forget how to put it back in... Good Luck
May 05, 2010 | Canon PC-1060 Black and White Copier
Stuck papers
Remove or open the right side cover of the copier , you will see the drum and the fuser unit. Press the two green levers on the fuser unit one on right and the left one down and look for a paper. If its stuck , open the front cover and turn the green knob. Remove the paper tray and check the inside of the copier and then arrange papers well.
Jan 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a peice of paper jam in the output area of the imagerunner 1670, but the machine dosn't open to allow access to this area. how do i get the paper jam resolved.
Your jam is in the fuser section of the machine. Unfortunately this area this area is not for users to access. You will need to remove covers to get to the fuser unit. You may be able to access the paper by removing the whole drum unit (make sure you remove the toner cartridge first). Then look into the machine to the left. You may see the tail end of the document for removal. Otherwise, you will eed a service manual to dis-assemble it yourself.
IR1600 Service Manual
May 05, 2009 | Canon ImageRUNNER 1670F Copier
PC1060 COPIER
Remove the drum unit,there are two clips that keep the drum and developer unit together make sure they are hooked in place.
Oct 18, 2008 | Canon PC-1060 Black and White Copier
Replacing fuser pc1610
Please let me know if there is a technical reference or service manual for the PC1060 (including Image Class D860) printers.
MXM450, Please let me know how to replace the fuser. I have spent an hour trying to get to the fuser but am not sure if it is from underneath the feeder assembly, or through the toner cartridge door.
Oct 04, 2008 | Canon PC1061 Copier
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
Canon PC1060
The fuser comes out the left side, not from the top of the copier.
Jun 20, 2008 | Canon PC1061 Copier
Changed fuser now scanner head stuck
hi i am a certified Canon tech on this copier. the problem you have is due to the scanner cable that runs from the top of the scanner to the main board in the back of the machine. what happens is when you take the scanner unit off to get to the fuser screw holes the cable should be removed from the main board under the rear panel with alot of screws. some people when they put the scanner unit back on they dont watch the position of the cable and when the unit slides back to open the cartridge door the cable is pulled part way out of the board connecter. the first thing i would do is to remove the back cover and chech the connector for the scanner cable to see if the cable is in all the way. also sometimes i have found that some one has pinched the ribbon cable damaging it underneath the scanner and replacing it with a new cable took care of the problem. the cable cost around $20. hope this helps.
Jan 04, 2008 | Canon PC1061 Copier
Canon PC1061 Copier Logo
685 people viewed this question
old marine
old marine
