Need baffles for potterton statesman 85/100 - Heating & Cooling
2 Suggested Answers
SOURCE: potterton statesman utility boiler making
Hi my boiler has just started to do the same. Have you had yours fixed and do you know what the cause was and how the problem was solved?
Thanks for a reply
Posted on Feb 28, 2010
How can I download an installation guide for potterton ep6002 programmer
Unfortunately unless you are trained as an installer of Potterton equipment you will not be able to get any advice from Potterton, they don't even supply direct to trade, everything is supplied through nominated suppliers, ie; Plumbers merchants.
This programmer should be quite easy to install I would have thought, in general all remote programmers have a mini wiring diagram on the back of the unit, though this will only show connections for the programmer outputs, ie heating on/off and water on/off.
If you require a wiring diagram for a complete heating system, you need to know the type of heating plan you have/are installing.
Hope this helps, if you need any more info get back to me.
I have just googled this and you can actually purchase from Amazon (not that I would do myself, I would use the merchants) there is a wiring diagram on the site. Just google Potterton EP6002, it comes up straight away Good Luck
May 23, 2014 | Garden
Install guide for ep6002 programmer
It would probably be best to contact Potterton or Baxi Potterton
at the email address: enquiries@potterton.co.uk
www.potterton.co.uk
Potterton Myson, send all enquiries to Baxi Potterton
I only found one PDF file online and it was a general book that showed how to wire most of the wire systems and controllers.
http://atibook.com/dl/en/Others/Tutrial/9780750664363_domestic_central_heating_wiring_systems_and_controls.pdf
Need Manual
Try the baxi potterton wedsite you can down load manuals there or they have at tech line
Nov 24, 2012 | Heating & Cooling
Need diagrame for potterton composite gas valve 402923
Look on The Baxi Potterton wed site you can down load manuals there or ask there tech line
Nov 07, 2012 | Heating & Cooling
How do u replace an ingnition control board in a potterton boiler
see follow the next step:
Adjust an oven flame:
  1. Turn all of the appliance controls to off. Open the door and remove the oven bottom and baffle (see above).
  2. Turn on the oven and inspect the flame.
  3. Identify the air shutter that will be adjusted. It may be at the base of the oven burner, just above the safety valve, or somewhere along the gas delivery tube.
  4. Loosen the setscrew that locks the shutter or plate, and adjust the opening to increase or decrease the amount of air mixing with the gas.
  5. Turn the oven on again to verify the adjustment, repeating as needed.
  6. Once the flame is correctly adjusted, turn off the oven and tighten the setscrew.
Check and replace an oven spark igniter:
  1. Turn all of the appliance controls off.
  2. Open the door and remove the oven bottom and the baffle (see above).
  3. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  4. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Jul 31, 2012 | Heating & Cooling
Potterton wiring diagram
Look on the baxi potterton wedsite you can down load mauals for your potterton or e-mail there tech line .
Feb 10, 2012 | Heating & Cooling
Potterton statesman oil central heating boiler the household oil ran out and i had it refilled and now the lock out button is illuminated i believe i have to press the burner reset button but not sure...
Hello my name is Heath it will be my pleasure to assist you. You will have to push and hold the reset in on the side of the control for 15 seconds. But you will also have to bleed the air from the system from the 3/8 nipple on the lower left side once the lockout has been released and the motor starts.
Sep 05, 2010 | Heating & Cooling
Potterton statesman utility boiler making screaching noise for 20 mins on start up then stops screaching and runs quietly!!!
Thanks for a reply
Feb 18, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
