Question about Philips 227E3qphsu 21.5 Led Lcd Monitor 16 9 7 ms / 227E3qphsu/27
There is NO menu button on this particular monitor. I've tried holding each button for lengths of time each, unplugging the screen and restarting the computer. What happened is that the picture on my monitor has shrunk, leaving 2 thick black bars either side of the picture and I know how to fix it, but the controls on the monitor are locked so this is impossible. Thanks in advance, Jack
Try hitting the start and the menu for several minutes well seconds (30) or until it pops bk on
Posted on Nov 08, 2012
benwabnick
  • 2404 Answers
SOURCE: OSD main controls locked and moving cursors by itself
i think the main board is flaky in that monitor. Hook up another known good monitor to that computer and see if it behaves in the same way.
If it does behave in the same way then you know its either the video card or the motherboard if you have an integrated video connector to the motherboard.
If it goes away then you know the phillips monitor is bad.
If its the phillips monitor that is bad for sure. You can try taking off the front cover and try cleaning the contacts on the main board in the front of the monitor. Could be that a few of them have dust or dirt and is activating those buttons by accidents inadvertently.
Posted on Jun 27, 2009
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Posted on Jul 18, 2009
  • 54 Answers
SOURCE: "monitor controls locked" message appear
If you haven't already figured it out, you need to press and hold the "OK" button for about 20 seconds-until the usual menu appears. This is how you unlock the controls.
Posted on Jan 10, 2010
pravinbhavsa
  • 348 Answers
SOURCE: The monitor control window keeps poping up all the
press the menu button and keep pressed for 10 seconds or untill OSD unlocked message will appear . same procedure for the lock .
Posted on Apr 19, 2010
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
OSD Lock out on HP Monitor
I've seen this solution suggested: Unplug the monitor from power. Hold the power button in for about 30 seconds to completely discharge the capacitors. Now power it back on.
If that doesn't work, go into the monitor's menu and do a factory reset. Hope it works now.
Nov 01, 2011 | HP f2105 Monitor
Osd main controler lockd
Hi there.
OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
The HP Fixes
FIX 1
Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
FIX 2
Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
FIX 3
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
FIX 4
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
The AOC Fixes
FIX 1
Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
Currently these are the most commeon fixes.
~ Slasher_X
Sep 28, 2011 | Philips 190B6CB/27 19" LCD
Hello, I'm currently running dual monitors - my main being a samsung syncmaster 2433 and the other being a viewsonic vx2255wmb. I've recently switched the viewsonic over to DVI, it was fine then...
Have you tried changing the input on the monitor? I've seen many times where people go all through the troubleshooting steps on monitors but forget to check that. Look for a button on the monitor that says "Input" and/or go through the menu and find the input section and make sure to check all of them, just in case.
Sep 08, 2011 | ViewSonic Computers & Internet
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
I keep pressing menu and it tell me OSD Locked? How do I unlock it?
This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One:Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Envision 19" Widescreen Flat Panel LCD...
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
LG W2243S - Keeps going into Safe Mode
Check your power source, maybe it is not getting enough power or getting to much power. Its happened to my amps before.
May 25, 2010 | LG 22" FLATRON LCD Monitor
Philips 227E3qphsu 21.5 Led Lcd Monitor 16 9 7 ms / 227E3qphsu/27 Logo
35 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
