Question about Acer Aspire 3680 Laptop
Lose contrast of the laptop
My lapton had a problem with the screen that is nearly black..
Windows 8 hp need administrator or power on password
and who set the laptop up origaniley perhaps they remember
Feb 21, 2015 | HP Computers & Internet
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
Toshiba laptop screen out, what cable is used to hookup to external monitor
You can use a VGA cable to connect the VGA out port of your laptop to externel monitor.
If your Laptop and Monitor has HDMI port, you may use that.
Dec 15, 2013 | Toshiba SATELLITE L755-S5214 15.6"...
My lapton went black screen
It is impossible to give you a a repair cost because I cannot identify the exact fault without looking and running tests on your laptop. I do not know the labour and parts costs in Malaysia.
I suggest you take your laptop to a computer repair shop and get a quote to fix your laptop.
Mar 01, 2013 | Acer Aspire Computers & Internet
I just had my Emachines D520 laptop display replaced because it was cracked. The new display is too bright, and the Fn keys that are supposed to control brightness don't work properly. When I use these...
Try going to control panel, then device manager, and try right clicking and updating all drivers that have to do with graphics or your screen. If this doesn't do the trick then try finding the display drivers manually.
Aug 24, 2011 | Acer Computers & Internet
My acer lapton screen is black and if I plug an external screen it is also black nothing display's
Hi ,
It sounds like your viedo chip on your motherboard went out , there is one thing you can try, start off by holding down the fuction key on your keyboard , followed by F1 through F12 to see if the computer screen comes back on and your system is not in the sleep mode other then that ots your viedo chip , you would have to check with the manf. to see if it can be replaced ..........Sorry ,,Good Luck Roy
Aug 19, 2011 | Acer Aspire 6920 Notebook PC
Why can't I change my background to my lapton screen?
Windows 7 starter will not allow you to do that. Buy, yes buy, a full version.
Aug 15, 2010 | Dell Inspiron mini 9 - Black , IntelĀ® Atom...
WHEN I SWITCH ON LAPTOP,THE SCREEN APPEARS BLACK AFTE USING FOR SOME TIME. IAM USING HCL BRAND AND OPERTING SYSTEM IS WINDOWS VISTA.PLEASE SAVE ME
I'd say your contrast is turned down, change contrast and brightness by pressing the buttons on your monitor.
May 23, 2009 | Dell Inspiron 6400 Notebook
New lcd screen displays four session of windows
try going to conecting an external display in the mobility center and set it to mirror your laptop
Nov 11, 2008 | Toshiba Satellite A105 Notebook
Samsung 50 in dlp
It sounds like the Screen is coming to the end of its life. Has the screen been recently moved or dropped? Plasmas tend to lose its contrast after 60,000 hours of use. It could also be a loose connection from your source to your TV. Have you checked all your connections to the TV?
Oct 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Acer Aspire 3680 Laptop Logo
24 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
