Question about HP Computers & Internet
Hp laptop won't shutdown
Everytime I shutdown laptop, it restarts again...only way to shutdown is to hit power button
  • 30 more comments
  • theresa_s580
    theresa_s580 Nov 08, 2012
    By the way laptop is windows7 64bit premium. I have had it a year,and treat it so well..hardly used!!. It's just a month out of warrant..now this happens!!!!!
  • theresa_s580
    Also. I have done a factory reset..and also tried in safe mode!!. What the hell has happened!!
  • max carson
    max carson Nov 08, 2012
    I am a bit confused by the statement,"hp laptop won't shutdown"? If you are on your desktop, click on the Windows "ball",go to start menu and click on "shut down" the computer does not start a shut down sequence? It may take a few seconds.
  • theresa_s580
    Thank you for your advice max. What I am saying is that I DO all that in correct sequence. All properties are correct. I am actually very good on PC...I am not a newbie...I normally can solve things myself...but this time I'm stumped.
  • theresa_s580
    theresa_s580 Nov 09, 2012
    Hi there Max. I havent written the whole sequence...because most would know what I am saying. Anyway...I go to the start orb..click..and then click on shutdown button. I have also checked the properties of shutdown button..ensuring it is actually supposed to be shutting down. I have been into registry and made sure that the relevant nos are correct pf the power shutdown sequence. I
  • theresa_s580
    And as far as maleware bytes, ccleaner etc...I have been using these for years. I also know what I am doing in the registry. You are lucky that you have never had this problem....because there are absolutely hundreds of people who have!! If you search google.
  • max carson
    max carson Nov 09, 2012
    I'm sure that you know where you are headed, Factory Restore from your Recovery Partition. I try to avoid that like "poison" , I have restored computers many times, Windows XP recently, the 100s of updates, it's a marathon, 36 hrs. I lost count of the pots of coffee.
  • max carson
    In your searches of the web did you run across this procedure: 1. Go to start and type device manager.
  • max carson
    I tend to over look the obvious at times, have you updated any drivers lately,if so disable them one at a time and try the shut down.
  • theresa_s580
    theresa_s580 Nov 10, 2012
    Im sorry Max..but problem is worse now. I did a system tune up via F2 on my laptop. Wanted to check memory, battery, hard drive etc. Everything said "Passed.
  • theresa_s580
    Now screen will not load up at all past hp logo. I can't even boot from disc to do a clean install
  • theresa_s580
    Im at my wits end!!. Thanks for your replies by the way..I know your trying to help
  • max carson
    max carson Nov 10, 2012
    I'm sure you saw this coming, Do you have any Win 7 disk? A win 7 repair disk? I have found when I work a problem for a long time it's good to ask for others advise. You tend to get tunnel vision. With 20+ years trouble shooting computers I assume nothing and use the "flow chart" in my head, 1) Is it plugged in. YES or NO. It's difficult to gauge one's level of expertise by a few word heading. Therefore assume nothing.That said, I do remember a problem with a HP Touch Smart IQ 506 that had two logons one would load as usual the other would began to load and go to a black screen for 5 + mins and after what seemed like a eternity would boot, short story long the graphic drivers, Nvidia Ge Force 9300 were different versions, go figure.
  • max carson
    As I'm sure you know, remove all power ,battery etc,Hold down on/off button to drain the capacitors, leave battery out, plug in start tapping the "esc" key moving right across the top of the F keys, repeat process until you get a response or give up, and put in another HDD or remove the HDD and test it externally.
  • max carson
    Have you opened the laptop and remove the CMOS battery, for an hour or so to try and restore BIOS to defaults? It sounds like a software issue, doesn't soukd like a bad HDD, but......
  • max carson
    If you can get to the"esc" Boot menu select DVD/CD etc. or F-11 System restore/recovery.
  • max carson
    A little moral booster, I once knocked-out the phone service of an entire town, Villa Gesell, Argentina, by a simple input at the MAP keyboard and hitting ENTER . Does that give you perspective.
  • theresa_s580
    Hi there Max...I like your moral booster by the way
  • theresa_s580
    Hi again. I am able to get into bios .F10. I have tried to change boot order to load from cd..so as to put windows7 disc in..I hit enter...but then screen just stays black..until I turn off power button
  • theresa_s580
    I have tried F11 for system recovery...but again I hit enter screen then changes to black...same scenario
  • theresa_s580
    Only thing I haven't done yet, is to take out the CMOS battery from inside case, as I have never opened the back before.I have been a bit scared, if you like!!
  • theresa_s580
    But I think I will have to give that a GO!!.
  • theresa_s580
    Thanks for all your help Max x
  • max carson
    If you have a HP machine the CMOS battery is simple to get to ,it's under the memory in my HP pivilion DV9320us laptop. I crack them open all the time, add memory, change CPUs, CMOS, etc. The All-in Ones are like laptops most anyway. The Gateway All in Ones are a stinker to Crack open, much like a **** shell. The machines I used to work on , these, PCs, laptops, etc., are like toys. ALSO did you verify that the disk you are trying to load the laptop with is a good copy, if you put it in another 64 bit machine does it "pop-up" a run.exe? In BIOS your DVD/CD is enabled, everything looks normal, clock is set...etc?
  • max carson
    As you know, altering settings in BIOS and the system registry are a minefield, I've stepped on a few and had to do system reloads, but I do that 1 or 2 times a year, and can be a "Villa Gesell, Argentina moment", I am just say'in. By the way, I fixed the phone system, Quickly, very Quickly!
  • max carson
    If you need a Windows 7 64 ISO Repair Disk it can be found here:http://maximumpcguides.com/windows-7/cre...
  • theresa_s580
    Thak you Max for all your help...it's been a pleasure swapping stories!! However, I have had to give in now...took it to an engineer today
  • theresa_s580
    He spent quite a bit of timwith it,wilst I was there with him He can't see what the pbem is at the moment.
  • theresa_s580
    I have left it with him..I feel like crying. He checked the hard drive.memory.. etc. He thinks it might be the bios
  • theresa_s580
    He agreed that it was nothing had done. Just have to wait now. I wl let yo knw what hapens.u
  • theresa_s580
    Thanks again. xx
  • max carson
    Do let me know, bye for now.
  • HP Master
  • 7,627 Answers
Could you be a bit more specific? Could you tell me the correct sequence you spoke of? I am trying to understand , you shut down using the windows 7 shut down and it re starts? Your response didn't clear up my confusion. I can remember ever encountering this. Just a thought have you done a Maleware scan lately? If not try MALWAREBYTES found at : http://www.filehippo.com/download_malwarebytes_anti_malware/Install and Run a FULL SCAN and a program CCLEANER found at : http://www.filehippo.com/download_ccleaner/ Install and Run, it's a good program to clean the junk files out and speed up you system. That a good place to start.
Posted on Nov 09, 2012
5 Suggested Answers
  • 334 Answers
SOURCE: hp laptop won't restart or come out of hibernation.
have you tried clearing the cmos? jump out the cmos pins on the mobo after pulling the plug. you may have to reconfigure some simple settings in bios after wards but no big deal let me know
Posted on Jun 12, 2009
SOURCE: hi .my laptop thoshiba satalite
hi dis is ravikanth when ill charging my laptop toshiba A300 its automitically restarting what is the problem plz tell me
Posted on Dec 01, 2010
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
  • 11800 Answers
SOURCE: My MSI MS-1683 Laptop With
That blinking underscore is the way in which the laptop's BIOS is telling you that it didn't find any Windows to boot to - it was completely corrupted.
The only thing left to do is to reinstall it.
Posted on May 29, 2011
My HP laptop completely shutdown on restart, But not on shutdown , have to press power button to turn it off
Adjust your power settings (you did not mention what operating system you have) Do a search in your RUN box for "Power Settings" Here you can chose the way you want things to run on your computer.
Aug 21, 2014 | HP Pavilion Computers & Internet
Why won't my Compaq Presario SR5712F cut on?
I would not recomend to CUT OFF. You can damage WINDOWS FILE STRUCTURE. Shutdown using menu or press once on power button.
Oct 30, 2012 | HP Computers & Internet
Dell e1505 won't power off
Check or Change the PSU or charger.
Jun 28, 2012 | Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
How to reboot an acer aspire one notebook
If the shutdown button on the start menu (bottom left of the screen with a windows logon by default, or the windows key on the keyboard) does not work you have several options to try.
  1. Hold down the power button until it shuts down (should be 5 seconds) and then restart it with the power button.
  2. Use the command prompt: Hold 'Ctrl' and hit 'r' to open the run dialog box. Type 'cmd' into the dialog box. type 'shutdown.exe /r -t 0' (lower case make sure to include spaces where I have and exclude the ' ' parenthesis) to force an immediate restart.
  3. If these option do not work then remove power to the device by first unplugging AC power and then removing the battery from the laptop
Aug 20, 2011 | Acer Computers & Internet
Power button problem in Compaq Presario Laptop V6307TU? I have a laptop - HP Compaq Presario V6307TU which, since a few months, starts automatically immediately after I shutdown or hibernate the laptop....
Windows corruption - either a driver is malformed or one of the Wake-up settings from the device or Power settings is wrong. Easiest way is to reinstall: use a generic XP install disk with your key and later get the drivers from the HP site.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3421162
Jun 29, 2011 | Compaq Presario Notebook
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
Each time I hit shutdown, the computer restarts
there may be a problem with the power options of your notebook
go to control panel>>power options
click advance tab
there will be a option
"when i press power button on my computer"
there will be a drop down text box select shutdown
this will solve your problem
Dec 29, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Shutting Down my LAP TOP
Check in your bios for the power settings - your laptop is likely set to wake on lan or some other hardware. Also, check in the windows power management for the settings in there.
Feb 12, 2009 | HP Compaq Presario v3000z Notebook
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
