Question about Poulan Garden
Troubleshooting a stihl 029 chainsaw
Doesnt run right
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
  • 63 Answers
SOURCE: chainsaw running problem
The saw is not getting enough fuel. It should take about 7 pulls to hit(on choke) and then another 2 too start(on run).Check the fuel line and filter first,a fuel line leak is the most likely culprit, very common. Change the air filter, it's cheap and will eliminate any air related problems that may be contributing factors, and it probably needs to be done anyway. If this does'n't fix'ya we will continue on.
Please rate!
I'm assuming the carb is not adjustable, if it is we can solve this in about 30 seconds-
Posted on Mar 18, 2009
SOURCE: removing handlebar on stihl ms 270 chainsaw
you have to take the top cover off of the engine and then remove the tab that holds the bushing in place alongside the engine. if you just start prying on the plastic plug from the outside of the handle you will damage the retainer. that holds it in place. If you have already done this, there is a solution.
Posted on Apr 20, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
Where can I order parts for a Stihl 029 chainsaw?
From any Stihl retailer or from Sears I think.
Jul 16, 2016 | Stihl Garden
How remove fuel tank from a stihl 029 wood boss ?
stihl have a range of pdf version workshop manuals for their equipment
go google and enter details and download the manual for your machine
Jun 18, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I have a stihl 029 chainsaw and the oil is coming out next to the muffler and not on the blade
If the clutch drum was not set on the oil gear spring properly the housing can wear out and leak oil. I recommend removing the clutch and inspect the housing.
See a local dealer like www.arcolawn.com for parts.
Good luck
Mar 25, 2011 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Hole in oil tank need to replace need help stihl 029
New Stihl parts and IPLs are proprietary. The only source of parts is eBay or Stihl.
Lou
Jan 24, 2010 | Garden
Garden Logo
213 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
