Question about HP LaserJet 2550L Printer
Piloto encendido Se le enciende el piloto del triangulo rojo
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
TechSaver
  • 93 Answers
SOURCE: me falta el regulador de corriente de esta impresora se me perdio
Por favor llama a HP Colombia, al siguiente numero telefonico:
01-8000-51-HP INVENT (01-8000-51-474-68368)
De Lunes a Domingo de 8:00am a 10:00pm
Ellos pueden venderte el regulador y te lo envian por correo
Gracias
TechSaver
Posted on Feb 07, 2010
puertobori
  • 7733 Answers
SOURCE: El indicador del cartucho de
Ve a eate enlace y descarga la aplicacion Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) luego abrela y empezara el diagnostico.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 01, 2010
puertobori
  • 7733 Answers
SOURCE: Hola como etas soy Liz,
Issue When the printer comes up with an error code on the front panel, we may have to perform the service test(s) related to the error code. Sometimes when we enter into service/diagnostic mode and try to perform a test, the printer may come up with system error 79:04 (non-continuable generic error). When this occurs in diagnostic mode, it is not likely possible to analyze it by pressing front panel keys (e.g., up arrow and cancel); the printer will likely be hung/stuck with the error. Solution To overcome this issue, ensure that no data cable is connected to the printer (Network/USB/Fire Wire). For proper use of the diagnostic menu, the printer should be in a stand-alone state (only connected to power). Once it is confirmed that the printer is in stand-alone mode, then enter back into service/diagnostic mode and perform the test(s) required.
Posted on Dec 15, 2010
SOURCE: A quien corresponda, tenemos el
Hola este problema, también lo estoy sufriendo... encontre la solución aquí, http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C5180-Power-Up-Power-Down-Problem-Loops-on-off-on-off/td-p/132152 son los foros oficiales del servicio HP, al parecer no se hacen responsables, es un fallo que ocurre a bastantes usuarios. Según comentan otros usuarios se ha de realizar la sustitución de unos condensadores, leer las 4 páginas del post. He dejado la impresora unas 3 horas aproximadamente en el bucle dichoso y finalmente ha arrancado. Igualmente en ese mismo post viene como hacer un reset a la memoria de la impresora.
Un saludo y espero haber servido de ayuda.
Posted on Jun 09, 2011
Tcsoff piloto de tablero y boton lado izquierdo de timon
Esta senal se refere a Sistema de Control de Traccion (TCS - Traction Control System) y va enlazado a la electronica y sensores del Control Electronico de Estabilidad (ESC - Electronic Stability Control), en ambos casos, sera necesario revisar conexion de cables de los sensores y pasar un escaner detector de fallas para leer los codigos de fallo almacenados en el modulo correspondiente.
Suerte.
Jun 11, 2013 | 2006 Hyundai Tucson
2003 Honda CBR 600 RR se apaga cuando acelero
Hola, An?nimo y los sospechosos habituales son:
1. Puerto inactivo, puertos de transferencia, chorro de aire lento obstruido.
2. Tornillo de ajuste de ralent? demasiado bajo.
3. Ajuste de la mezcla de combustible de aire demasiado delgado.
4. Piloto / chorro de combustible lento obstruido.
5. Bomba del acelerador defectuosa.
6. Nivel de flotaci?n demasiado bajo.
7. Float cuenco contaminado combustible viejo, agua, suciedad, ?xido, etc
8. L?nea de ventilaci?n del recipiente del carburador obstruida / bloqueada / pellizcada.
9. L?nea de combustible al carburador doblada o pellizcada.
10. El filtro de combustible est? obstruido.
11. Fuga del m?ltiple de admisi?n.
12. La tapa del gas no est? ventilando correctamente o el sistema de ventilaci?n del tanque de combustible est? bloqueado.
13. L?nea de vac?o desde el colector de admisi?n hasta el grifo roto, agrietado o no conectado, l?nea de ventilaci?n del carburador conectada.
14. Aguja y asiento atascados cerrados en el recipiente de flotador. 15. Multi carburadores no sincronizados.
16. Bomba de combustible defectuosa.
Para obtener m?s informaci?n acerca de su problema y las valiosas descargas "GRATIS" que necesitar?, haga clic en los enlaces azules a continuaci?n. Buena suerte y tener un d?a maravilloso.
Dies when given throttle CBR Forum Enthusiast forums for Honda CBR Owners
Bike idles perfect but dies when given the slightest amount of throttle 93...
2003 2004 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Oct 07, 2012 | 2003 Honda CBR 600 RR
Que significa chekch
Una señal luminosa "check engine" le está diciendo que la computadora que controla el motor de su auto ha detectado un problema que causa que el vehículo produzca excesivas emisiones. En ocasiones la luz será acompañada por una notoria serie de problemas en la respuesta del carro, como pérdida de poder del motor o dificultades para encender, pero otras veces el vehículo puede operar "normalmente".
Las fallas comunes que pueden causar que se encienda el "check engine" incluyen:
- Falla en componentes del motor como los sensores de oxígeno, temperatura del refrigerante, presión interna (MAP) o de flujo de aire.
- Motor que no enciende debido a fallas en las bujías, cables, componentes del encendido, inyectores de combustible u otras partes del sistema de combustible.
-Fallas en el sistema de control de emisiones como mangueras de vacío rotas o sueltas, el tapón del tanque flojo o desaparecido, o una defectuosa válvula de recirculación de combustible (EGR).
Si se enciende y luego se apaga tras unos instantes, puede ser un problema momentáneo en el sistema. La luz se apaga cuando el problema se detiene, pero la computadora debe haber guardado un código de diagnóstico de problema en su memoria. Si la luz no regresa, puede ignorarla. Sin embargo, si la luz se enciende y apaga intermitentemente, lleve el vehículo para que lo revisen y puedan escanear el computador para determinar que codigos de falla hay almacenados en el.
Suerte (recuerca calificar y comentar esta respuesta).
May 14, 2011 | 2004 Chevrolet Impala
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Luz roja intermitente en piloto de encendido, que indica esa luz roja en lc19sb25u sharp
La soluci?n no es exactamente para este modelo, pero si tiene el IC 2001 te puede servir.
Conecta a masa las patas 81 y 82 del IC2001 durante unos 15 segundos.
A ver si se te soluciona.
Saludos.
Apr 07, 2011 | Televison & Video
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Mi Equipo de sonido KENWOOD modelo UD-551M se apaga solo...
hola mi equipo kenwood ud551m tiene averiado micro funciones del amplificador donde lo puedo conseguir al componente gracias ana desde uruguay
Sep 19, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Encendido del LC-32GA5U
no abla espanol this is america translate your question first
Dec 30, 2007 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
HP LaserJet 2550L Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
