Question about Hitachi 53FDX20B 53" Rear Projection Television
Hitachi 53SDX01B, audio but no picture
Picture kept getting darker & darker. Took back off tv and blew dust out of tv then had no picture, completely dark. locate 7 leds (5 green and 2 red, all brightly lit except on circuit board on right side where 4 green & one red leds are located. The green led closest to rear of tv is dimly lit compared to all other leds. Fuse where power cord comes into tv is alright. Where do I go from here I have no matenance manual.My 8 year old Hitachi CRT 53" was a little weak for the last few years (dirty?), but then over the course of 4 or 5 days suddenly got progressively weaker until picture gone completely. Unplugging for a day and and repowering does no good. Will take cover off and look myself but I am reluctanct to spend $153 on diagnosis since it's so old. Any ideas?
    Sergeant:
  • 367 Answers
There is a light bulb (Lamp) you will have to replace it is standard. For rear projection they are quite expensive. Although cheaper than the tv.
Posted on Jan 05, 2009
    Genius:
  • 1,550 Answers
Did you check the bulb ?
Check to see if the horizontal output transistor is shorted or not .
  • 679 Answers
Its a main board fault needs a repair.
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture wnt out suddenly without any symptoms
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Apr 13, 2009 | Curtis CM32020S 32" TV
Hitachi TV: 35TX30B Window in upper left view that won't go away
you using a digital desk top box with it ?
an old school tv
solid state old analog
what you are seeing is called picture in picture
one of those split screen functions of years past
remote may have a function button on /off for that
user manual for one
Hitachi 35TX59K 35TX50B 35TX30B Manuals
Apr 06, 2017 | Hitachi Televison & Video
Plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Mar 24, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
BIG SCREEN TV
2.5 ohm resister at 2 watts at R43 is bad on the 53sdx01b same boards as my tv , when mine went it was at 12 ohm instead of 2.5
Jul 02, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SDX01B Rear Projection Television - No Picture
i have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
Apr 04, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Convergence Problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
