Question about JVC KW-XR810 Car CD/ MP3 Player
JVC KW-xr810 pushed the Fwrd, to go to next song, all of sudden it starts to fast forward thru the song, i cant stop it, or turn unit off , any button u push, doesnt do nothing, i even took one of the battery cables off.
GARYDALE
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
  • 3 Answers
SOURCE: JVC KD-LHX500 has power, but won't turn on!
Replace the 15 amp spade fuse in the back of the unit. See if that get you going again. If that doesn't do it then check your wirin Black goes to ground, Yellow is a constant hot, Red is a hot trough the fuse box, Blue is for your power antenna if you have one, the Orange with a White Stripe is to the Illumination and is also hot.
Posted on Nov 12, 2008
  • 8 Answers
SOURCE: Radio doesnt start.. Keylock?
take the removable front panel off
on the main unit you will see a small hole near the bottom on the right
this is the unit reset switch
you will need a paper clip or something similar to press the reset button
this should completely reset the head unit
hopefully this should sort it
Posted on Feb 13, 2009
FixMyConsole
  • 174 Answers
SOURCE: I cant get the jvc radio to turn on time will
What model have you got/
It's 2 Possibilities of faults.
Either a diode leading to the faceplate connector has gone open circuit (common in JVC)
Your ignition supply is down (or the voltage regulator is not outputting the correct voltage to turn on)
I'm very sure it is the diode problem. I used to work for a national car stereo repair company, so if you need any help give me a call.
FixMyConsole
Posted on May 24, 2009
etirbynnor
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
JVC CAR STEREO DECK MODEL NUMBER KW-XR810 ONE WEEK AFTER INSTALLTION OFF KENWOOD AMP DECK STARTED SKIPPING AROUND ON THE PRESET CHANLES AND.THIN THE CD IN THE DECK STARTED PLAYING NOW THE CD IS STUCK IN...
It sounds like you may have a stuck or bad switch. Try checking to see if any of the buttons are jammed. If they all seem fine, you will need to check the switches with a multimeter set to check resistance.
Dec 30, 2014 | Car Audio & Video
I have a JVC in dash CD player its I think a sw68 one day I was mashing the search button repeatedly while searching for a song on my USB flash drive when all of a sudden it wouldn't turn.... Here's the...
I also had a JVC unit in my old car, unsure of the model. It was used prior to my purchase, like the car was, and the SEEK > button was the same way. It would kind of stick down/pressed in, and very rarely work, and most the time it DID work was when I wasn't even pressing any buttons. all other functions of the radio were still there but because the connection behind the SEEK > button was shot, I just spent next to nothing on another radio/cd player. it may depend however if your unit is new or an older one like mine. best of luck!
Jun 06, 2014 | Audio Players & Recorders
JVC KW-xr810 source changes by itself/randomely. IS it a swc problem with my Tacoma?
I would suggest you install a 12 Volt power filter to the device in question, this will filter out any spurious electrical noise that may be triggering this problem, These filters are available on line and any auto sound supply store or center.
Jan 15, 2012 | JVC KW-XR810 Car CD/ MP3 Player
How to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds. One of the PSM items appears on the display. 2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears. 3 Turn the control dial to adjust the hour. 4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display. 5 Turn the control dial to adjust the minute. 6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
May 05, 2011 | JVC KW-XC770 CD / Cassette Player
Problem with MP3 player-Stops after one song
On closer look (after my long road trip to test this out), I realize when you hit Browse, there's a button on the bottom titled Play All. If you select this button, the buttons mentioned above work as intended, and the Forward, Backward buttons bring you to the next or previous songs in the list.
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Jvc kd-g200 cd player
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=260a73e6d269444e666771376ad18c85&q=JVC+KD-G200
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
Apr 17, 2008 | JVC KD-G200 CD Player
Setting the time
turn clock on
Press the SET buttom (red Clock icon will come on)
Use fast fwrd / fast Revs button to move clock forward or back
Press the set button when done
Mar 10, 2008 | GE Spacemaker 75300 Shelf System
JVC KW-XR810 Car CD/ MP3 Player Logo
913 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
