Question about HP Deskjet 6940 InkJet Printer
Paper jam; paper "wrapped around roller -- OK to pull it out?
I don't want to mess up my 6940 HP so when I got a paper jam (which is still jammed), I hesitate to just pull it out. A cartridge is also "stuck" on the left side of the jam. How can I clear this? Without a manual I'm scared to mess around with it. Can you solve this AND send a manual? Thanks so much for whatever you can do !
Simply pull out the power cable then just simply open the back cover and pull gently on the paper.
do not just rip it out... Gently and it should be fine
hope it helps
Posted on Jan 06, 2009
Paper jam, unable to pull paper out
Yeah, I would be careful though and only take out what screws you have to and document where they came from.
Jan 08, 2010 | Samsung CLP 315 Laser Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Paper Jam that pulls paper to the right and crooked then get error message no paper
Hello
You have either a rubber roller that has gone completely bad or more likely there is something still stuck in the printer - probably a piece of paper wrapped around part of the feed roller. Open it up and examine carefully with a flashlight. If you can't find any foreign objects then wipe down all the rubber rollers with denatured alcohol.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Clear paper jam in top feeder of HP 3055
IT HAPPENED TO ME, I HAD TO TAKE HP ONLINE HELP, BUT ACTUALLY U WILL HAVE TO OPEN THE WHOLE AFD LIKE LITERALLY UNSCREW IT OPEN CAREFULLY AND THE ROLLERS AND THEN U MIGHT MANAGE TO TAKE OUT THE JAMMED PAPER
Apr 02, 2009 | HP LaserJet 3055 All-In-One Printer
Paper Jam in HP2600n printer
Very difficult to disassemble. You should call a HP Service Center.
Jan 22, 2009 | HP Color LaserJet 2600n Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
Aug 08, 2008 | HP Deskjet 6940 InkJet Printer
Major Paper Jam
The paper is jammed around the fuser roller, you will have to remove the fuser and clean the mess.
Dec 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
HP Deskjet 6940 InkJet Printer Logo
245 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
