Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Burnt out power supply board
I believe the capacitors (several) are burnt out. The P/S board has black tar-like stains on it near several capacitors. The tv will not turn on anymore. Can I buy a new / refurbished board or do I have to take it to a repair shop. I believe Astar is out of business.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Http://www.flickr.com/photos/byziol/
Photos of board and caps
where to get them
Posted on Jan 16, 2009
  • 2,326 Answers
I repair these power supplies. If you need further assistance, write to jah2mil@hotmail.com
Posted on Jan 05, 2009
Power supply board not the problem- need further input please
Typically if one inspects the boards in question you may find evidence of heating and damage. Sometimes with newer solder having no lead, hot spots tend to leave cracks around the joints of parts heating and cooling and once they arc they fry components. One can usually smell a burnt component altho hard to describe the smell. I would look for burnt fuses on the power board where the power first enters the back of the tv, and some fuses are covered with a plastic sheath and looks like another type of component. A tester comes in handy... I suggest that you look more at the board that gives the high voltage to the TV screen, as there are step up transformers (square blocks) that give a lot of trouble and the transistors surrounding those blocks, usually 4 transformers. I would test for continuity around these areas but the transformers should be pulled from the board for a more accurate test. Inspect transistors (black with three prongs) usually has an aluminum heat - sink attached to it for cooling, anything more than 3 prongs is probably an IC or integrated circuit chip. These are more difficult to test. A diode will allow power one way but not the other so reversing the polarity tester tips will give you a voltage or nothing in reverse. Transistors are similar to a diode in that you can test it one way but it shouldn't be a reading the other to try to keep things simple. Typically when a transistor goes it will burn a hole in the face or on top. A capacitor looks like a mini soup can and swelling on top a hole on top or liquid stain under it is an indicator that it's bad. Typically the top is swelled and the plastic coating bares most of the top of the capacitor. If one inspects other capacitors in that area you can notice the difference even though indicators are slight at times. I would at very worse put the screen part away until you found a suitable tv model with a broken screen perhaps on kijiji. Typically it is a capacitor that has blown but may only lead to a partial solution to the problem if several parts are gone which is usually the case, a capacitor or two as well as a transformer or a transistor; and one must also inspect and test other components in that same area for success and to inspect the circuits for cracking around components especially where the hot areas are and one can usually see these hot areas due to the discoloration of the board in these areas. These hot areas are usually the problem. One overall solution is to build a big fan into these tv's lol and put surge protector bars on all your expensive electronic components.
Dec 05, 2013 | JVC LT-37X688 37 in. LCD HDTV
SAMSUNG PS42AS5 PLASMA TV POWER SUPPLY FAULT 470MFD CAPACITOR BLOWS NEAR POWER SUPPLY
First thing you should do is to invest in a really good surge protector for your TV. Then when you replace the capacitor again use a good capacitor. Cheaper is not always better. Rubycon seems to do the best for me. There may be other suggestions, however I have the best luck with them.
Apr 03, 2013 | Computers & Internet
My ACER 22" monitor goes black after computer
What model Acer do you have? Email me at tech@ccl-la.com and I will try to help you get it going again.
Jul 03, 2012 | Computers & Internet
Toshiba 50hpx95 made popping noise then went black, now power light is blinking red. wont turn on
Hi, It sounds like you have an electrolytic capacitor that blew up( can be a bit noisy ) it'll more than likely be in the power supply section somewhere-it's not totally dead hence the blinking light ( which is a fault indication ) The bad component should be visible by possible signs of swelling on the top,( silver colored) a rubber seal on bottom being pushed down around the two metal leads near the circuit board , or even some brown discoloration around the faulty component/s,( it does not have to be a capacitor) I have heard integrated circuits pop before ( they will almost always leave a smoke stain near where it occurred ) also there may actually be a small hole in the faulty part. I hope this helps, Make sure unit is unplugged before servicing, good luck, Prodzilla
Mar 31, 2011 | Toshiba 50HP66 50 in. Plasma Television
I have a 52'' samsung and when you plug it in it just keeps clicking on and off. i let it do it for about 4-5min and it turned on but the picture was shaky and only black and white.
that tv is very common for power supply failures. there will be several bulging vented capacitors on the power board. the capacitors are used for filtering in the power supply so they would smooth out the ouput of the certain switched supply circuit they are part of. easiest way would be to replace the power board otherwise with some minor soldering skills replacing the capacitors is cheapest route. the capacitors are near the top right corner of the power board which looking from the back of the tv is the board on the left. usually there are about 5 capacitors total that need to be replaced.
Jan 07, 2011 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
I turn on my samsung syncmaster710 and it just has a black screen, with a faint (very faint box floating around it. is this a fualty backlight?
The backlight invertor seems to be defective.
Check the main power supply board for bad capacitors (visible damage ) and make sure that the invertor tubes do not light up for a moment when you power up the monitor ( in that case their probably is one or more light tube defective (burnt)) --
Sep 18, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
Astar LTV 2701 power supply
I have aquired an Astar LTV 2700 and believe parts are missing. Any idea where I can get the Schemetics for this tv. E-mail me please. sonshinerider@yahoo.com
Oct 24, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Televions
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
May 25, 2008 | Philips 26MF605T/17 26 in. LCD Television
AL178 17in. Flat Panel Problem: Screen goes black after about a second
hi,
I had the same problem before. I open my set to find out the faulty component are at power supply main board.
I change the electrlytic capacitor 680microfarad and a resistor burnt near the FET.
You can visual check first.Color changes and bulky form on cap and burnt resistor easily.
Have a try.
Apr 13, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
143 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
