Question about Saws
I am thinking to replace Aluminium fences near pool area.Can anyone suggest me expert fencing contractors?
My Aluminium pool fences looking dull in color and breaking.I just need repair contractors which replace broken fences in reasonable price.
Few days back i had also facing this pool fencing broken problem due to heavy storm and rainfall.Then anyone suggest me about experienced contractors they give me quality services at affordable prices.They also provide pool safety certificate after full pool inspection.If you want to avail their services then i feel glad to provide a link here.You just go for it and see the difference. http://pool-safe-inspections.com.au/pool-fence-repairs/
Posted on Nov 08, 2012
Editor925
  • 285 Answers
SOURCE: Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Posted on Mar 01, 2009
efs_perpends
  • 1996 Answers
SOURCE: fence will not lock in place
You adjust the handle tension by actually adjusting the t-square itself, changing the relative position it sits from the rect tube mounted to the saw.
This is done by turning the two allen set screws mounted in the angle iron that is welded to the fence. There are a couple of tabs that ride along the inside face of the rect tube when the fence slides from side to side. You'll see that each of these tabs is adjustable, in or out, by slightly turning the allen set screws with an allen wrench. BOTH of these must be adjusted, so that you maintain the fence's 'squareness' to the table.
What I do is line up the edge of the fence with the mitre slot in the saw table, feeling the edge of the fence as it hangs over the edge of the mitre slot, both at the infeed and outfeed end of the slot. It should be perfectly flush at both ends.
By turning the set screws in or out a little, you can adjust the handle tension to the place where you like it (you don't need to force it into position to have it hold firmly; that's too tight). Then check the squareness of the fence by clamping it down along the edge of the mitre jig slot, and see if it's parrallel. If not, you need to adjust one or both screws to make it parrallel, and get the tension right. You may have to go back and forth a few times, but eventually you can dial it in to where it feels just right and the alignment is correct. Think small adjustments.
At the same time, put a little dab of wheel bearing grease or vaseline on the cam of the fence handle where it rubs against that little flap. This will make it easier to engage when the tension is firm and keep it from wearing abrasively.
This fence is a joy to use when it's dialed in. I hope you find this information helpful. Happy woodworking!
Posted on Mar 25, 2009
  • 187 Answers
SOURCE: can't align fence properly - table saw 36-650
Depending on the manufacturer it is possible to get a little movement from below but you don't want to through off the alignment to the table. If you do the the pusher will bind on the blade. You may be able to file off some of one of the adjustment screws or replace one with a longer one. Good luck
Posted on May 08, 2009
Editor925
  • 285 Answers
SOURCE: Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Posted on Jun 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Posted on Jul 18, 2010
What are the different types of services included in Landscaping means?
Decorating the garden is the best way to make your house look beautiful from exterior. You can add up to the beauty of your house by organizing your outdoor.
Landscaping services includes:
  • mowing loan and maintaining it
  • paving walkways
  • lightings in surrounding
  • planting beautiful shrubs. flowers, plants,etc
Moreover you can do something from your side too.
  • You can put beautiful furniture suitable to your garden to enjoy nature that surrounds you.
  • One can also put some beautiful aluminium security fence around your house. This helps in security as well as decoration.
Aluminium Security Fence Aluminium Fencing Installation In MN
  • You can also plan to build some waterfall and rock garden. (This also comes under landscaping business)
May 14, 2016 | Garden
Tip
Help Keep Fungus Off Your White Vinyl Stockade Fence
Do you have a beautiful white vinyl stockade fence surrounding your property? Want to minimize the amount of times you have to clean it due to mold, etc.
If you do or if someone you know does, remember when the fence was first installed in the yard....God wasn't it really pretty.... then after a few months of the damp and hot weather do you remember seeing the green mold starting to form all over it???
Well I have a suggestion for not only cleaning this form of plastic but for also helping to preserve it against any further mold growth in the future.
I mix a solution of bleach and 1 oz dish soap in a plastic bucket along with an anti fungicidal swimming pool solution approx 6 oz. of this to two gallons of water and two cups of bleach, I also combine a car wash/wax solution 2 oz. in with the mixture to help preserve the plastic finish and to help fend the green mold from taking hold of the fence.
I try not to use a power washer as they seem to only hit the fencing so hard they open up the pores in the plastic leaving the fencing vulnerable to any further mold growths that may occur in the near future.
Use a soft bristle with a telescopic handle and a good pair of water proof gloves with protective eye wear .
The anti fungicidal solution is used in swimming pools to prevent mold from forming on the plastic liners so I figured it can't hurt to use it on the vinyl fencing material as well, for any of you folks that have washed down these fences I am sure you dont want to do this too many times in a 12 month period, so whatever works will be greatly appreciated.
I hope these little ideas help you all and as always....
Happy Mold Cleanup!!!
on Aug 03, 2010 | Garden
My chain link fence is rusted in a few different areas. Should I replace the entire fence, or is there a way to fix it?
Hi Jessica:
Surface rust should have no effect on the structural integrity of the fence, and a totally acceptable cosmetic fix should be able to be obtained using galvanize paint.
Notice I said COSMETIC fix. If the fence is no longer structurally sound, it may be time for some major repairs or replacement.
Jul 15, 2015 | Home Fencing
Does anyone know where I can buy cheapest fencing?
The cheapest fencing will depend upon the type of fence material.
Try Google the Internet for the type of fence, you will get various suppliers and prices or check out the local classifieds.
Apr 02, 2013 | Sport & Outdoor - Others
How much should a wooden fence cost?
Of course it depends on the dimentions of your yard. Wooden fences can be quite expensive. look at this site, it includes installation costs:
http://www.homewyse.com/costs/cost_of_wood_fencing.html
Jan 31, 2013 | Home Fencing
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...
don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
Need to line up the blade with the fence
I take the blade out of my tri square and lay it between the fence and the blade and let it touch the blade. Then I set the fence tight with the tri square blade.With the blade against the fence you can position the saw blade just where you need it.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the question queue. Thank You for choosing FixYa.com.
May 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Fence gets a slight bow in it when tightened
look at the far end of the fence for a nut that you can loosen slightly when in the unclamped position. It sounds as if you are clamping it so tight that you are bowing the fence
Mar 21, 2009 | Delta Saws
Saws Logo
817 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
