Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher washer gwl10us looking for manual so I can take it apart.
Thanks
3 Suggested Answers
  • 1294 Answers
SOURCE: I have a gwl10us
First check to see if water flow is good at your wall faucet, coming into machine.
Then check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe would be good too.
Posted on Jun 05, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Posted on Dec 15, 2008
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
I am looking for a manual for a Fisher-Paykel washing machine. (Just rented an apartment and trying to figure out how to operate this appliance). Peter
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | Fisher and Paykel Fisher & Paykel Washer
My GWL10us will not go into spin
Hi just read your posting.Now just a couple of question,Is the machine draining the water?Is the machine stopping completely and beeping? Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel GWL11 Top Load Washer
Holes in clothes from washing
Yes - it's been happening to us as well. Any idea what it is? We have model GWL11 US
May 13, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I have a gwl10 and during the wash cycle there is water coming in but the drain pump keeps running during the fill cycle.
The pump itself is supposed to run during the fill portion of the REGULAR cycle. It is supposed to be mixing the incoming fresh water with your laundry detergent and pouring the solution on your clothes as the tub rotates slowly. If the water is draining out of the machine, then there has been some sort of issue with the DIVERTER VALVE. It either has a broken lever on it or an object has become wedged in it, holding it open all the time. If you try the PERMA PRESS cycle, you will probably find that cycle will work, as it does not use the recirculate function.
I would check the diverter valve first. You can tip the washer back and remove the hose clamps with no tools and shine a light up inside and look for an object. You also can inspect the lever and will clearly see if it is broken.
If the washer needs a diverter valve, the part number is a 426862P and is easy to change. You can get them from Fisher Paykel Parts:
http://www.fisherpaykelparts.net/111-4/Diverter-Valve-GWL10-11-15.php
They also have downloadable service manuals (but I have pretty much told you what you need here)
Here is the GWL10 manual:
http://www.fisherpaykelparts.net/115-15/GWL10US-Service-Manual.php
Dec 19, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL10US won't spin
hi
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
Oct 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
I have a gwl10us
Jun 05, 2008 | Fisher and Paykel Washing Machines
FisherPaykel GWL10US won't spin
diverter valve malfuntion water is recirculating instead of pumping out
May 28, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
