Question about Dell PowerEdge T300 Server
DELL PowerEdge R710, E1810 error, cable not connected, foreign disk
4 Suggested Answers
  • 12 Answers
SOURCE: We have a Dell Poweredge
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Posted on Sep 09, 2010
  • 1833 Answers
SOURCE: I have a PowerEdge 2950
According to u I understand that the hard disk of your Power edge is faulty & need to recover the data.
You don't have say the exact problem of your hard drive. If your hard drive detect in your system Bios but you can't access Data or OS from safe mode also then try to format only the OS drive or repair the drive with your server OS CD. If you get perform it well then you can recover your data by transferring data to another external drive.
If The Hard drive doesn't detect then first try to change the cables (Data & Power)of the Hard drive. If detect it then try to access it or perform the previous job.
For detection of the Hard drive you can try to attach this drive to another system in slave or as secondary drive. If detect then you can recover data.
If your hard drive get crashed then use data recovery CD to recover data. Insert disk, install software, and recover the data by follow the option of the software.
This software is available in market.
Have another process to recover data from a crashed Hard drive. It is freezing but try it carefully. Place the hard drive into a baggy, seal it tightly and put it in the freezer overnight.The next day remove it from the baggy and put it in the external drive case.
Transfer the data from the drive before it warms too much and crashes again.
Posted on Jan 27, 2011
info2u
  • 596 Answers
SOURCE: I have a Dell Power Edge 2950 running on Ubuntu.
You may have a damaged hard drive and it needs to be replaced. If the system is still under warranty, Dell will replace the drive free, you just need to go online, supply your systems tag number and follow the instructions from there. If you have just the one drive, you will need to restore the information froma a backup. If you have a RAID set up, once the hard drive is reinstalled, the RAID will sync the drive to the others.
Good Luck
C2Solutions
Posted on Oct 15, 2011
Dell poweredge 6600 no display
If the "vga cable not working" then it is not "all componets connected correctly."
Nov 13, 2013 | Dell PowerEdge 6600...
My server name is powerEdge2900 and SAS Hard Disk. My server have RAID(Mirror). I lost my password of my server. I want to break RAID.How can possible? please ans. me .........
What raid is it in? For example if your server is in a raid 5 you needto take out hard drives enough to only have 2 in place and then put 2 more in to make a total of four and get it to rebuild it.
Please advise that you are taking it at your own risk and that you seek my solution as your last one. Thanks
Source: I been handling 2950, 1950, r710 dell poweredge servers for the last 4 years, i install 200 a month.
Aug 23, 2013 | Computers & Internet
Replacing Server HDD
Hello here is the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/poweredge-r710
Yes, that will be okay.
But a SSD harddrive is much faster, than the old mecanical one.
I know they are a little more expensive, but you will see a speed improvement, you have newer seen before.
Good luck
Jan 29, 2013 | Dell PowerEdge Computers & Internet
Problem to install poweredge r710 can nor detect sata hard disk
That is an impressive piece of kit. Is it under warranty ?
You should probably have it professionally serviced but you can always check whether it detects a known good drive. You can also test the suspect drive in another system.
Before you do anything ask yourself: What changed last (or recently)? There find you will that which disturbs the force.
Make sure that the connectors are all fully inserted. This means both the power and the data cables. Try different cables and a different power plug.
Sep 01, 2012 | Dell PowerEdge R710 Server (D263K)
Installing Dell PowerEdge R710 DVR Server
  1. VIA a serial cable (looks like monitor cable is not). You have use something like telnet. Old school and very technical.
  2. Just connect a monitor, keyboard, and mouse and treat like a regular PC. Can't go wrong.
Aug 21, 2012 | Dell POWEREDGE R710 E5520 226G 2P 4GB...
I have a Dell Power Edge 2950 running on Ubuntu. Is there any program that i can run to check my hardware because i had a Error message E1810 HDD disk failure. i remove the disk and put it back on but i...
Good Luck
C2Solutions
Oct 14, 2011 | Dell PowerEdge 2950 (becwfk1_6) Server
Dell PowerEdge R710 Installation error I have the same problem while installing Windows Server 2003 installation process reach to the step asking press F8, when pressing F8 it says no Hard Drive were...
ok you will need to get the windows 2003 drivers for your raid controller and put them on a floppy disk. when you first boot off the cd you will see a prompt to press f6 if you need to install any additional drivers. insert the floppy disk and select which driver you wish to load.
you should be able to see the hard drives now to partition/format.
Mar 09, 2011 | Dell PowerEdge R710 Server (D263K)
Error message E1810 HDD 0 Fault
go here
http://support.dell.com/support/edocs/systems/pet300/en/hom/html/about.htm
Jun 09, 2010 | Dell PowerEdge T300 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
Dell PowerEdge T300 Server   Logo
659 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
