Question about Altec Lansing ADA 885 Computer Speakers
Smal display showing me hd and speakers don't work
    Problem Solver:
  • 12 Answers
Scan your PC for viruses.
If still not working format your PC and run any sample song without installing any game or soft as they may contain virus.
Posted on Nov 08, 2012
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
Jan 16, 2012 | JVC Car Audio & Video
How to test the mulltitester in a speaker
Hello
There are mainly two type of multimeters. The first type is analogue one, which will have a needle deflects inside its dial to show measurements, and the second one is digital, which will look like a handheld calculator, in which measurements are displayed digitally. You can read it diretly from it.I don't know which type of multimeter is you are using. If it is digital one, set it to Ohms range, and connect the tow meter probs to the two terminlas of the speaker. Before doing this, check the impedence, marked on the speaker magnet. Usually it will be marked between 4 & 8Ohms. You must get this marked Ohms measured on meter scale. For bothe type of multimeter, the proceedigns are the same.Please don't hesitate to rate this solution. OK.
Dec 23, 2011 | Sony Audio Players & Recorders
I have a luxor 32" lcd tv and i cant get my surrond sound speakers to work. how do i do this?
Hi well surround sound speakers require an "Interconnection" box, that is a box with Jacks that the Red & White stereo audio plug into, on one side, and the 3 SS speakers plug into the "Other side" as it were. Usually with SS we have a Rear, Front and Sub Woofer, as this means 3 sets of speakers must mate with the 2 outputs from the TV etc. So the "Line Out" stereo output from the TV, which are usually the Red & White, is the output to the interconnection box, from there it feeds into the SS decoder, some plug directly into the decoder itself, and don't use an interconnect box, but it's all the same in the end. The stereo output is fed into the SS decoder, and then SS signal is extracted from the sign in, and routed out to the appropriate speakers.
Oct 21, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Just bought a ps3 secondhand but no scart lead do i need one?
You don't need a scart lead for your ps3 if you have a HD television. All ypu need is the HDMI cable (which is not included with a new PS3 but you can get very cheap from Ebay- don't bother with 'gold plated' or other 'high quality' cables as they are all the same output quality). The HDMI carries audio and video to your HD television, but you can use a scart lead for audio if and the HDMI for video if you want to use external speakers. The ps2 scart cable also works for the ps3 if you don't have a HD television. (note: a HD television is highly recommended because the quality is a hundred times better). Mine is a Samsung HD monitor which you can buy fairly cheaply.
Jul 28, 2011 | Video Game Consoles & Games
My Mirage S10 subwoofer light comes on showing the subwoofer is on but I cannot get any bass sound to come on. How can this be resolved?
More diagnosis first. We can't assume the source is squawking bass to this thing and you don't mention that you know that to be the case. IS it? The problem could be up the food chain.
We also don't know if you're feeding it Speaker Level or Line Level.
Prove the subwoofer amp is dead or alive by jacking in any source you have that has an RCA output (Tape Out on your unnamed source, CD, TV, etc). Turn the sub volume down to minimum to start as most RCA outputs are at maximum volume. Try that to assess the amp's health. Still dead? Get it worked on.
Jul 07, 2011 | Mirage Prestige S10 Subwoofer Speaker
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
Altec Lansing ADA 885 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
