Question about M-Audio Nova Professional Microphone
I cannot get it to work with garageband - won't take any sound in
I've tried everything. It's connected to the M-Audio Fast Track Audio interface. Sound Input on my computer is set to the device. Sound output on my mac is set to the speakers. I can't hear any sound through GarageBand and it wont record my voice. Curiously, when I unplug the XLR I can get feedback from the end of the cable, like when you bang it. You can hear the banging sound through the XLR.
  • 1 more comment
  • jamiesteedma Jan 05, 2009
    Yes it is a condenser mic. What is phantom power? Is that from a battery? The microphone can be screwed apart at the bottom and the middle section slides off from the top but all that is inside is some circuit board. There doesn't seem to be anywhere for an external power cable or a battery to go. It is an M-Audio Nova (Large-Capsule Condenser Microphone.
    Thanks for your help.
    I am using this Audio Interface device called an M-Audio Fast Track. It is a USB device and I have the mic connected to it via a XLR cable and then it is connected to my mac with the USB. I think I've realised from what you've said that I'm going to need either to get a new mic that doesn't require phantom power or I will have to get another Audio Interface or preamp that actually is powered from the mains and has something like a power switch (which will give power to the mac). This makes sense as just now the Fast Track is only drawing power from the computer via the USB. I hope I can resolve this without having to buy another mic - it cost about £100.
    I have to say I'm a bit disappointed with M-Audio - there was no instructions on how to set up the equipment at all. We've all got to learn from somewhere.
    Thanks so much for your help. I really appreciate it!
Turn on the phantom power in the back of the fast track!
Posted on Oct 14, 2009
  • 716 Answers
Is It A Condenser Mic? If So You'll Need Phantom Power
Posted on Jan 05, 2009
  • Michael Fisher
    Michael Fisher Jan 05, 2009
    Well If You Have A P.A It Would Have a Phantom Power Button And Like Me I Have A Br-1180 And It Has It Built In As Well. Phantom Power Is More Power. You Dont Need A Battery You Need An Inline Phantom Power For What Your Trying To Do. You Know They Sell A Usb Version Of The Mic Your Using. Call Your Local Guitar Store And Ask Them About Something To Go Inline Or Maybe You Can Exchange Them For The Usb Version Of These Mic's.
    Hope This Helps You.
  • Michael Fisher
    No Problem. You Record Music Or What?
SOURCE:
I have an error message that says: Error wile trying to synchronize Audio and MIDI Sample Rate 38441 reciognized. Check conflict between GarageBand and external device. Any suggestions?
what you need is a "FULL DUPLEX ASIO DRIVE",which you get with programs like cubase sx, this is like a universal driver which has always synced any audio equipment i've hooked up to my computer, internal & external.make sure it's the full duplex & not the asio4all v2.
But really you shouldn't be having much trouble if your using a USB midi interface.unless your computers sound card is ****.
try resetting the sound cards sample rate to 44100HZ which is the standard rate for most audio,or 48000HZ for digital.
May 16, 2011 | Tascam US122 Audio/MIDI Interface with...
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
I have an Alesis io2 audio-interface and a macbook pro. I'm using garageband software. I plug the interface into the macbook before I load garageband. (So standard protocol.) My problem is that when I...
sorry about your problem, i have the same issue. i think i solved i'm by using my midisport 2x2. Alesis fucked up on the midi with this unit. use an other midi sort, and that may fix the problem.
Jan 06, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
Oct 19, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
Connecting an M Audio Fast Track USB to a Behringer XENYX 1002
I suppose that you connect the behringer mixer master out (just one of the two channels in case of two) to the guitar input of the Fast Track. Have you tried to hear your mic from the phones output at the front panel of the Fast Track? Try changing the guitar gain and the output level at the top of the Fast track.
I'm waiting for your results or clarification, please post.
Thanks and regards
Stelios
Oct 21, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Open Questions:
See all M-Audio Nova Professional Microphone Questions
M-Audio Nova Professional Microphone Logo
2,663 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
