Question about Garden
No start on poulan pro snowblower
I have a poulan pro snow blower that will not start. i have checked and confirmed that i have both fuel and spark. it was purring like a kitty when i shut it down in the spring with very little fuel in the tank. so far i have : refueled with fresh fuel, replaced spark plug, changed the oil, and cleaned the carb (did not adjust any thing) any ideas?
5 Suggested Answers
johncaman
  • 201 Answers
SOURCE: Poulan saw will not start
This is not really a solution.... I can't post a comment. I think you know where I was going with the flywheel thing - whether or not the timing is right. I thought you'd pulled the flywheel yourself, and sorry, I'm not sure how to pull it. I'm assuming this is a 2 stroke motor... you might want to just check that the piston is near top dead center when the magnet on the flywheel hits the coil..... you can stick a pencil or anything long through the spark plug hole to give you an indication if the piston is at the top of the cylinder or not. Let me know how it goes!
Posted on Mar 14, 2009
picatudo
  • 239 Answers
SOURCE: Stihl strimmer will not start
timing
Posted on Jan 02, 2009
  • 15 Answers
SOURCE: poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Posted on Nov 08, 2009
  • 81 Answers
SOURCE: mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Posted on Dec 09, 2009
Snow blower runs well then dies to a rough idle
Sounds like it has dirt or water in the carb and is slowing down the fuel flow and starving the engine of fuel.
Feb 16, 2015 | Poulan Pro 27" 2Stage Snow Blower Electric...
How do I adjust timing on a poulan pro snowblower
Factory Set, you can not truly adjust the Timing, most people find that the Carburator or Spark plug will fix 99% of everyone's problem
May 13, 2014 | Poulan Garden
Need belt size for poulan pro 96194007 snow blower
Is there a part number on the belt itself? Try googling the model number and putting in belt.
Mar 01, 2014 | Poulan Pro 24" 2Stage Snow Blower Electric...
Starting poulan pro snowblower
gas spark and air , if you have these 3 it will start , which one do you not have
Jan 12, 2014 | Poulan Pro Pr621 21-Inch 208cc LCT Gas...
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Snowblower will turn over but will not start.
check to see if its getting fuel if it is then change the spark plug if it still doesnt start then a carb kit is needed
Jan 18, 2011 | Toro Snow Blower Scraper For S200 s620 New...
Garden Logo
1,418 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
