Question about Dell Dimension 4400 PC Desktop
Windows will only start in safe made after sp2 or 3 install
I have a dell deminsion 4400 with xp. It already has sp1 installed but when i try to install sp2 or 3 it will only start in the safe mode. I have adaware and avast antivrus installed on this computer and have run both before install.
  • nfloyd52 Jan 06, 2009
    No luck
    just as the windows XP screen appears it goes black and starts booting again and the second time goes to the safe mode screen.
  • 116 Answers
You likely have some software issue that prevents all the new services from loading, most likely it is related to the antivirus/security software.
try disabling all the non-MS Services and all statup items in MSConfig, if it starts normally with all this disabled, reenable them a few at a time until you find the offending software
type "MSCONFIG" withou the quotes
click the services Tab
check "Hide all microsoft services"
click disable all
click Satrtup Tab
Disable all
allow to restart
during startup you will see a screen that says you have made the changes, this is normal (when you are all done, check the don't show again)
once you have found what causes the issue, Google the startup item and uninstall the related software.
Hope this helps
Posted on Jan 05, 2009
  • 2 more comments
  • Ron
    Ron Jan 06, 2009
    What can you see?
    How far does the boot go, since it does not appear to be a software issue, it must almost certainly be a driver issue.
  • Ron
    Ron Jan 07, 2009
    It does not flash a bluescreen?
    Try setting the system not to restart on an error (press F8 during startup, then select the option that says not restart on an error). If there is a bluescreen you will be able to see it now (note the descriptor, the error code as well as any file names mentioned on the screen)
    Also, disconnect any items possible (printers etc, and if you have a wireles card, souncard etc, take that out or disconnect it). If it is not in startup, it is likely a driver issue.
  • Ron
    Ron Feb 04, 2009
    In safe mode, go to device manager
    In device manager disable the Video Card (under display adapters), right-click disable.
    then restart in full windows (I choose the Video card since it is most likely). If windows starts it will do so without the Video driver.
    If it is the video driver, reinstall it with the latest version, if it is not the video driver, try some other devices.
    If it starts in Safe mode, but not full windows with everything disabled in MSConfig, it is almost certainly some driver that windows loads, especially at the time you describe the issue starts.
  • Ron
    Ron Feb 06, 2009
    One more try, I was researching something else and ran into this.
    Start your computer in Safe Mode.
    2) Click on Start, Run, and type REGEDIT and press Enter. This will open the Registry Editor
    3) Click the pluses(+) next to the following registry keys
    to navigate to the correct spot.
    * SYSTEM
    * CurrentControlSet
    * Services
    * Intelppm
    4) In the right hand column find the entry titled START and double-click on it
    5) Change the number to 4 and click Ok
    6) Close the Registry Editor
    7) Shut down your computer and restart
    This time the computer should restart normally and finish the installation of SP3.
    worth a shot
I have downloaded the disc for visioneer 4400 usb scanner. The software is there but Vista says there is no scanner hardware? It had been working on my old desktop but now I am trying to install it on my...
make sure that when you installed the software, that the scanner wasn't plugged into the laptops USB port. That is a known issue with USB devices. If they are plugged in during the install, there's a good chance that they may not work. Always wait for the software to prompt you to plug the device in
Mar 04, 2011 | Visioneer 4400 Flatbed Scanner
I have change my ops from vista to windows xp pro i cant not fine the drivers for vista ml3108b note book can you help me pls. thanks
Hello no1sugard, go to this "Website," and "Download the Updates" for Windows XP
(Service Pack 3)."
  • First make sure that you have [SP1 and SP2] already installed in your Computer?
  • To {check} which "Service Pack" you have already?
  • If not?
  • Then you must "Download SP1 and SP2 first!"
  • Open "the Computer Properties," by [Alt / Right] clicking on the Computer in the 'shortcut menu' of the "Start Menu."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here:
Feb 21, 2011 | E-Machines eMachines Refurbished EMA...
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Run Windows in safe mode.
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Well if you have it installed on the computer and cant get past the Windows logo. Put the SP3 disk in and do a repair. Make sure you hit -R and not the repair button after clicking continue. Well the directions for a repair will be on the screen. That is my thoughts on what you should do. If you have already done this, then I'm not sure where you should head to next. Hope this helps!!
Mar 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have dell inspiron 1545 laptop which come with vista home premium sp1. i want to install xp sp2 but it gives error. plz help me
1.Please shut down the computer. 2.restart the compuer and without wasting anyting start tapping F8 key(up and down.) on the keybord. You will see windows advanced option. using the up and down key on the keyboard, please select safe mode with networking and hit enter. 4. now, you computer will be restarted in the safe mode. 5. please try to install sp2 here.
Jun 10, 2009 | Dell Computers & Internet
Cannot logon to system
Format and reinstall a fresh copy of windows xp.
You can try to use windows recovery console but it also asks administrator password.
Apr 26, 2009 | Computers & Internet
Problems when installing sp2 on my dell 4400
Reboot and keep tapping on F8 into Safe Mode. You can select "Last known good configuration" or continue In safe mode and do a system restore to the day before you installed the SP3. To do a system restore, go to Start, Programs, Accessories, System Tools, System restore. Windows XP SP3 has some issues with certain programs giving the blue screen of death.
Jan 04, 2009 | Dell Dimension 4400 PC Desktop
My Dell Dimension 4400 running windows XP Home Edition stopped working and displays a blue screen with the following message: STOP: c000021a {Fatal System Error} The windows Login Process system process...
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Dec 07, 2008 | Computers & Internet
I want to re-install Windows Xp to get SP3, but my computer.
it's not your hard drive it's sp3
they have been having problems with this.
go to and download it from there.
Dec 03, 2008 | Dell Dimension 4400 PC Desktop
Trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
Oct 30, 2008 | Dell Dimension 4400 PC Desktop
Dell Dimension 4400 PC Desktop Logo
137 people viewed this question
Alun Cox
