Question about Vector Maxx SST Power Inverter
Im tring to buy a battery bank
I have to power 1800 w for 12hr a day!
I currently have
Vector Max SST 3000w
20 Duralast 31-950
950 Cold Crankin Amps
195 Reserve Capacity
Schumacher se-3000 Charger
Do i need to change or add anything to get the bank to work?
Right now it doesnt last 12 hours a day. I need it to run cosistantly. I was think i may need another type of charger. What do you think the problem could be?
3 Suggested Answers
  • 3 Answers
SOURCE: I have to power 1800
I think the problem might be your battery setup.
First of all, these batteries are not deep-cycle batteries they may not tolerate this kind of usage. Secondly, if you have 20 batteries connected in parallel they could end up working  against each other (draining each other) all the time.
You might do better with 2 very large 6 volt deep-cycle golf cart or fork lift batteries.
Posted on Jan 11, 2009
get a duralast 900 recharger and starter from autozone.com duralast charrge lasts for 3 months of charging and starting cars boats ect. also it has a built on light and an additoional accs attachable flexible light.
Posted on Jan 23, 2013
On the 15-12-2014 i bought a lloytron 5 in 1 wireless headphone, the manual says i need a 4.5V DC adapter for mains but nowhere does it say the amount of (amps) needed before i buy one,since there are so...
I would think anything over 300 mA would be ok. But I would go for something around 1 to 2 amps.
As long as the voltage is 4.5 it doesn't matter if the current is 10 Amps or a 100 Amps. They will only draw as much current as they need. The maximum working current is only 30MA.
Receiver:
Max consumption current 30MA
Power Supply 2 x AAA batteries
Transmitter:
Frequency 85
Transmitting Distance 10M
Complete Voltage 3V
Max working current 7.5mA
System mode RF
Power Supply 2 x AAA batteries or 4.5 DC not included
Dec 18, 2014 | Audio Players & Recorders
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Dec 03, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
What size battery does 2004 Dodge Stratus RT need?
HI. This vehicle only requires a maximum of 750 cranking Amps; ((640 Cold)). A regular name brand Gold-Duralast 12 volt cell will be sufficient for this vehicles needs.
Nov 21, 2010 | 2004 Dodge Stratus
Vector 3000 watt model VEC051D
Time for a new inverter. Lesson learnt I dare say.
Check polarity!
Sep 05, 2017 | Vector 3000w
What type of battery to use in 2001 ford taurus
does not matter what kind anybrand just as long as it is 500 to 800 cold crankin amps
Feb 24, 2009 | 1998 Ford Taurus
I have to power 1800 w for 12hr a day! I currently have Vector Max SST 3000w 20 Duralast 31-950 950 Cold Crankin Amps 195 Reserve Capacity Schumacher se-3000 Charger Do i need to change or add anything to...
Jan 05, 2009 | Vector Maxx SST Power Inverter
Vector Maxx SST Power Inverter Logo
109 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
