Question about Cannondale Cycling
Cannondale swingarm replacement
Could the rear swingarm of the "moto1" be replaced by another model's swingarm
    Master:
  • 388 Answers
Only Moto1 swingarms fit on them. Swingarms are specific to models.
Posted on Feb 02, 2014
How to change drive belt
You have not provided the year of your motorcycle so here is the directions for a 2006 Harley-Davidson Touring Bike. If you need advice as to how to change a belt on a different model year post again with the model year and ask again. If you need directions on how to remove the rear/replace any or all of the rear wheel or the swing arm or the primary case or the starter or the front or rear drive sprockets or etc etc post another request and if I see it I will respond to it.
2006 TOURING DRIVE BELT REMOVAL AND INSTALLATION
Remove the rear wheel and the rear swingarm and then the primary chain case assembly and then the old belt from the transmission sprocket and then install the new belt on the transmission sprocket and re-install the primary case assembly, the rear swingarm assembly and the rear wheel.
Jul 14, 2014 | Harley Davidson FLHRCI Road King Classic...
Need to replace rear shock cannondale Jeckel 1000
What year of jekyll is it? What's wrong with your old shock?
Feb 22, 2014 | Cannondale Jekyll 1000
Lefty shock axel bolt removal
I would need more information, but it sounds like that the bolt is most likely stripped and in need of replacement. Your local Cannondale dealer should be able to get one of those for you.
Mar 18, 2013 | Cannondale Jekyll 1000
Primary drive belt replacement
What model bike? Sportsters are simple. Others you may have to disassemble the left side of the swingarm (rear fork). If you are attempting this repair yourself, I would highly recommend getting a service manual for the bike. They aren't cheap, but have all the info you will need and will pay for itself after doing this one job!
Jul 22, 2012 | Harley Davidson FXD Dyna Super Glide...
How to change a swingarm on a harley davidson flhtc
Remove the rear wheel, brakes and shocks. Remove the silver plugs in the center of the passenger footboard mounts. Remove the rear floorboard mounts, and the rubber mounts behind them. Remove the bolt on the left side of the swingarm pivot. Chances are the pivot bolt is rusted in, so you may have to pound it out with a drift. Replace the rubber mounts when you put everything back together.
May 28, 2012 | Harley Davidson FLHT Electra Glide...
Derailleur hanger for connondale flash carbon 4 2010 i think the part number is kp 121
What's the question?
Use a Search Engine for it and you will find many for sale. Also check eBay.
Go here and find all the documents on hangers...
http://www.cannondale.com/manuals
Jun 15, 2011 | Cannondale Derailleur Hanger For Rear...
We are looking to buy a 19996 ST1100 and the swinging arm has been welded. Is this the correct procedure or shoud it have been replaced?
It depends on the quality of the weld. There is nothing wrong with welding a swingarm on an ST1100 as is shown here. Replacing a rear swingarm can be expensive.
If the weld is good, everything should be fine. If it's poor quality welding, a replacement swingarm would probably be needed.
Mar 17, 2011 | Honda STX 1300 Pan European ABS...
2003 FXD swing arm wobbles
If the swingarm wobbles from side to side, you need to replace the swing arm bushings. You'll have to support the engine/transmission while you remove the swingarm. Once out, you can drive out the old bushings and replace them with new ones. It's not that big of a job except for pulling the rear wheel. Just watch the sequence in which the parts on each side of the swingarm come out and put them back the same way.
Good Luck
Steve
Jun 07, 2010 | 2003 Harley Davidson FXD Dyna Super Glide
Head gasket it has oil in the radiator
Hi, Craig_compto maybe you should replace the head gasket sorry you can't find the first and best tool you ever bought for your Cannondale despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
cannondale 440
Oil cooler leaking antifreeze into oil
http://www.cannondaler.com/manuals.php
http://www.blackwidow-ok.com/pdf/5002339-Motorcycle-Parts-03-models.pdf
http://www.blackwidow-ok.com/om
Apr 09, 2010 | 2003 Cannondale E 440 R
Cycling Logo
75 people viewed this question
Top Cannondale Cycling Experts
John Egan
John Egan
dante
Tom Chichester
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
