Question about Apple Macbook Computers & Internet
Macbook display display partially gone
  • 1 more comment
  • Craig Bing Nov 10, 2012
    Here is an image of what I am dealing with.
    Can you be more specific about which ribbon cable that I should try to reseat? And if there is specific instructions to do this so Idon't further harm the computer. Thank you!
  • Khan
    Khan Apr 13, 2013
    Seems like the there are lines on some part of the screen or some area is black. If that is the case, changing the screen will help. Thanks. Tech fromhttp://www.computerstar.ca/mac-repair-ap...
    Master:
  • Apple Master
  • 545 Answers
If you're not comfortable with disassembling or reseating cables, it might be best to pay for it to be done. You can find full disassembly instructions for your specific model at ifixit.com
The cables to check will be both from the system board and on the back of the lcd screen. You'll want to start with the motherboard cables, see if that works, and if it does not, try the one on the lcd. I say this because disassembling the lcd is a little scarier than the lower case.
Posted on Nov 13, 2012
  • Craig Bing Nov 13, 2012
    Thank you for the detail. I will give it a shot and reply further.
  • Craig Bing Nov 15, 2012
    After tapping on backside of the lcd Display panel (left side of apple logo) I could see that the display blocking would come off and on. This tells me it's most likely a loose ribbon like you mentioned. Unfortunately I do not have the tools to pop off the panel to reseat the ribbon so I will take it in to the local Apple store to see the costs. APpreciate the feedback and pointing me in the right direction.
Can only get a partial screen with netflix. Audio fine
Change your resolution settings in System Preferences. Open System Preferences, and Open Displays. Then Click resolution size: Best for Display.
Jun 10, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
Macbook pro 17" checkered screen
It is likely a solder joint gone bad between the GPU and the board due to more ecologically friendly but more brittle non-lead solder. You can either take the computer to an Apple store and consider the cost of having the motherboard replaced (roughly $600) if it's no longer under warranty, or search for local technicians who are familiar with "reballing" the GPU (which shouldn't cost more than $200US). Be aware that a replaced motherboard may just be a swapout from another MBP manufactured under the same conditions. Read this article for more information. Class Action Lawsuit Filed Against Apple Over 2011 MacBook Pro Graphics...
Jan 18, 2013 | Apple MacBook Pro with 17" Display
Hi i have an apple display connected to my macbook
Unplug the display from your macbook, and restart your macbook, when it's fully restarted and you are logged in, plug the display back in, then check to see if it is detected. Macbooks don't like to be put to sleep (shutting the lid) with a display connected, this causes issues with display detection. So always unplug your display and wait about 5 seconds before closing the lid on your macbook, and when you open the lid, wait another 5 seconds before plugging in your display. The only time it is acceptable to leave the display plugged in when you close the lid is when you plan to use the macbook in clamshell mode, this is done by plugging in and configuring your display, shutting the lid, and then "waking" the macbook from sleep mode with an external mouse (wired or wireless will work). That will start the macbook using the external display as the main display, without even turning on the macbook built-in display. Never connect or disconnect an external display when your macbook is off or in sleep mode. Have a nice day.
Jun 26, 2010 | Apple Cinema Display Flat Panel Monitor...
1/3 screen display
Sounds like the inverter for the video has gone bad.
Jan 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
MBP Graphic Chip Failing
Flickering screen, solid horizontal or diagonal lines of light, start up but no screen. Connect another display to the DVI port, if you get a signal, the display is toast, if not- the GPU is. APPLECARE?
Aug 12, 2008 | Apple MacBook Mac Notebook
No screen activity on startup
hi wa_flyboy,
I suggest you first do a test to determine if it is your macbook's screen or graphics processor which is at fault. To do this you need to connect an external display to your macbook.
The macbook has a mini-DVI port for connection to external displays. Depending on the connector of the external display you use to do the test, you are either going to need a mini-DVI to DVI adapter (for a DVI display) or a mini-DVI to VGA adapter (for a VGA display). These adapters are sold separately by Apple, see http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa/wa/RSLID?nnmm=browse&mco=669DFFE0&node=home/shop_mac/mac_accessories/displays
If an image is displayed on the external display after you have connected it to your macbook, you know that the screen of your macbook is faulty. In this case it would be an economical option to take the macbook to a repair shop where a technician can determine the faulty component (either one of the following display components of a TFT LCD screen can fail over time; the inverter, the backlight or the cabling). These can be replaced under warranty or they can order new ones if the warranty has expired.
If the external display shows the same symptoms as your macbook's display, it is the macbook's graphics processor which is at fault. I'm sorry to inform you that I think this is the cause of your macbook's display problem. Replacing the graphics processor of your macbook entails replacing the motherboard.
If the macbook is still under warranty I suggest you replace it and let technicians migrate your data from your current macbook's hard disk to your new one.
If the warranty of your macbook has expired, it's a more economical option to buy a new one and migrate your data to the new macbook. This will only cost a few dollars more than the cost of replacing the faulty motherboard (including the service costs of the repair shop to which you take your macbook), but is still more economical seeing as how you get a new machine which has a full warranty.
I hope this is helpful information and thanks for using the FixYa services
Kind Regards
Feb 13, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
130 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
