Question about Samsung DV218AEW Electric Dryer
How do u check to see if the dryer vent is plugged
    Problem Solver:
  • 22 Answers
  • Check your lint screen. If there isn't much lint on it and you've been doing laundry, it's possible the lint may have been caught in the vent instead of the lint screen, which means you have a clog. Lint in the area around where your dryer is can also be a sign of a problem. For More information please visit Dryer Parts.
Posted on Nov 08, 2012
My beko dryer keeps tripping my electric box
We had similar problem with a different type dryer. Turned out to be a weak / older / bad breaker in the electrical panel. Every so often it would just trip the breaker for no reason.
The owner thought it was the dryer itself - and bought a new one - but problem remained.
In our case - solved by electrician putting in a new breaker in the panel for the dryer.
Could still be your dryer though, in your case.
Suggest:
- make sure dryer vent is not plugged by lint or other stuff.
[ When running, check that you've got good flow of hot air coming out the outside vent. If NO, could be a plugged up vent. We've had that too before. Disassemble, clear out vent tubes, check for plugged up screens, on the outside too, there is sometimes a screen in the outlet - it could get plugged. The screen is important - to keep out leaves & animals & stuff - but typically gets plugged up. Then dryer overheats and shuts itself off or trips the breaker. Also - you'll find that it takes longer to dry anything if the flow of air going out is restricted.]
Oct 25, 2013 | Dryers
LONG DRYING TIME
Most likely the vent is plugged - check the vent hose (usually start at the outside location & work back to dryer). If hose is not clogged, unplug dryer, remove vent hose from back of dryer and check there.
Aug 02, 2012 | Roper REX4634KQ Electric Dryer
I have a Maytag Quiet Plus ll Model # MDE9806AYW. We found water in the dryer vent. Do you have any idea what could be causing this?
A plugged outlet vent. Start the dryer and go outside and check the vent. It should have a strong air flow. It the air flow is not strong check all the vent tubing and the outside vent.
May 31, 2011 | Maytag Dryers
Does not dry my clothes well and only had it 28 days
check your filter[clean if dirty]-check & seeif your vent is plugged-check to see if the vent doors outside the house open when dryer is on -[also maybe proppeler might have become stuck or loose, it sounds like a plugged vent problem.
Dec 22, 2009 | Maytag MEDC400V Dryer
Over heats , and has lots of moisture vapor coming out of the bottom.it dries and everything ,but its like it's leaking water
The most likely cause is your home vent is clogged and the dryer has little or no air flow. The water is exiting the dryer with the air since there is little air flow which causes the "water leak". Clean your home vent all the way through and your dryer will probably also need a good cleaning. This should take care of the problem. Please rate this post.
Dec 14, 2009 | Dryers
My maytag gas dryer has always taken a very long time to dry clothes....usually 2 hours. I have had it for 8 years and it has been this way the whole time. is this normal?
i would check air flow out of vent normally with plugged vent extreame amount of moisture is present in dryer on high temperature of air moving through dryer is
max about 140 degrees normally with room temperature arpund 70 the drying time is normally 60minutes or less
contributing factors to long dry time
pinched vent hose final rinse cold water
below 50 degrees remove vent screen inside dryer clean with hot water shine flashlight into vent opening verify not plugged if have candy or probe type
temperature gauge verify temperature
at vent exit
Dec 12, 2009 | Maytag PYE2300AY Electric Dryer
Maytag MDE8600AYW takes way too long drying clthes
either your house vent is plugged, or the vent in the dryer by the blower is plugged. when the vent is plugged, even partially, the moisture is not leaving the dryer. It will take a long time to dry, and the top of the dryer will get hot when the vent is plugged. Clean the house vent and check down below the lint trap by the blower, then it will dry fine again.
Oct 09, 2009 | Maytag MDE8600AY Electric Dryer
Loud noise in dryer, and no air coming out the vent
Check these things:
Unplug or turn off the power to the dryer and turn off the gas (if equipped)
Pull out and examine the lint screen
Pull the dryer away from the wall (carefully), disconnect the vent pipe (the 4" tube) and look for plugging of the vent line (you said the vent dampers weren't open)
Lastly, it could be the vent blower - this is located inside the dryer annd accessible from the back with the back cover removed. The blower could simply be plugged or it could be defective.
May 07, 2009 | Dryers
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Samsung DV218AEW Electric Dryer Logo
123 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
