What connections are required to set hard drive function (Master, Slave, etc) in this case for use on a USB extender
Trying to recover data from this drive. Purchased a USB extender to plug into another computer to read this drive - but the four pins which determine how the hard drive is to be configured (Master, Slave, Ext, etc.) are not connected in the extender. How must I interconnect these pins to allow me to read the drive data through the USB extender?
  • 57 Answers
Doesn't matter where the pins are if the drive is being connected via usb because it will act as a internal drive. If anything, just set the jumper to Master.
Posted on Nov 08, 2012
msuhelk
  • 106 Answers
SOURCE: slave pin settings
PLACETHE JUMPER IN THE MASTER AT FIRST POSITION AND REMOVE ALL JUMPERS FROM YOUR SLAVE DRIVE IT WILL BE DETECTED AS SLAVE... :-)
Posted on Apr 12, 2008
  • 9 Answers
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Posted on Mar 20, 2009
geraldo14200
  • 48 Answers
SOURCE: Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Posted on Apr 06, 2009
preachw996
  • 1179 Answers
SOURCE: pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
Posted on May 23, 2009
  • 17 Answers
SOURCE: Take Three: I have an older Maxtor Hard DriveTake
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Posted on Dec 18, 2009
How i recover my data?
download a free program called RECOVA.......this great and free program will scan your hard drive and then give you a long list of programs and files to recover. Warning, if you have installed other programs on this computer you may have totally overwritten your lost data! Good luck
Feb 26, 2015 | Hard Computers & Internet
Im just wondering why i might need a slave drive, i have a 80 gig master and a spare 80g drive should i put them both in or does it realy matter
slave drive is very handy in backup files you can store data and other software and drivers. it does matter becouse master drive always has the operating system that the virus and error always happen. hard drive with IDE connector has two jumper setting slave and master. connected to IDE cable. sata disk has no master slave..
Aug 18, 2011 | Computers & Internet
Him I need to recover data from an Hitach Travelstar HDD N155 ? Is it a SATA ? Do I need to connect it to a pc as a slave using a cable ? Which kind of cable ?
This drive is an IDE type and not SATA, which means you will need an adapter like this one so you can plug a data cable and provide power. You can then connect the drive to a regular desktop PC.
You can set the jumper on the drive to make it a slave and hook it up on the same IDE cable as your primary hard drive, but the jumpers on the laptop drives are teeny little ones and I personally find them hard to deal with. What I do is unplug the data cable to the optical drives which are on the second IDE channel, then plug the laptop drive cable there. Then the drive can remain jumpered as master.
Another option is not to bother opening the PC at all, but to get an external hard drive case like this. Then you could just plug the drive in on a USB port and copy your data, and you'd have an external drive available for future use.
Good luck with the recovery, and thanks for using Fixya!
Dec 04, 2010 | Hitachi Travelstar 80GN 60 GB Hard Drive
Samsung HDD does not get detected any more. I have very important data and want the data to be recovered at worst case. HDD is old one and makes strange sound when connected. Even if I connect it in...
Try to connect it as a master. Just connect this hdd only, so we can know if is detected in the bios. If yes then there's a possibility that you can recover your data. If you hear clicking noise/strange sounds then there's also a big chance that your hdd is broken. If it is detected in the bios, then remove it again and try using an external casing so you can put this hdd in it and connect it to your pc thru usb. I assume that your hdd is an ide and not sata since it's old as you say. Then to go to windows and see if your hdd in external casing is detected. Another option is that if it is detected in the bios, use a bootable cd with software apps for Hard disk tools like HDD Regenerator or HDAT2 to check and repair bad sectors on your hdd. Use this at your own risk and may destroy all data on your hard drive. If noe of this works, then you can assume that your HDD is not functioning anymore.
Nov 03, 2010 | Samsung Computers & Internet
Western Digital My Book Essential Edition 1TB Hard Drive I drop it and broke the USB connection. I connected it internally but it is being found as a non formatted drive. How do i recover the data?
It would appear the the shock not only damaged the USB connector but also the drive. You could try Hirens.BootCD and carry out a RAW recovery and you may be lucky and recover some of your lost data. If not then it will be gone forever as you have damaged the plates inside the hard drive itself
Jul 20, 2010 | Western Digital My Book Essential Edition...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
How do I Recover data from an old hard drive
This may sound silly, but does the external enclosure have power? You may have neglected to connect the required power adapter, or it may not be working properly. You might also have a problem with the enclosure's internal power or data cables. They are sometimes pretty flimsy, and sometimes they can go bad.
There's also the chance the drive itself is bad and isn't being detected as a result. Or the interface board in the external enclosure may have failed, and the drive is OK but the computer doesn't see it. If you are connecting to a desktop PC, you can try connecting the drive directly to the main board using an IDE cable and try accessing it that way. Just be sure to set the master/slave jumper accordingly if you do that.
Feb 07, 2009 | Western Digital USB 2.0 External Enclosure...
My laptop cant se my external hard drive
Hi hot_lips_swe
If you've tried everything possible to access it through the external,what I would do, is to dismantle the case around the hard drive, and take out the physical hard drive and switch the back pins to Slave, and add it to a desktop if you have one. (make sure you have your main drive as Master) Then as a slave drive you have a lot more options to recover your data. If you don't have a desktop, you can purchase a laptop port extender at your local computer store. Or you can buy you HERE, and connect it direct to the usb port. Your best way is to slave the drive on a desktop thou.
Good Luck
Mark
Jan 20, 2009 | Western Digital My Book Essential 500GB...
Maxtor slave settings to recover data
Leave your original drive in your PC set as master, set the T1600 to slave
Open your desktop, click my computer and click C drive, reduce the window so you can slide it to one side, click my computer again and then click G drive if that is what the slave is called. Make a new directory in C drive and give it a name, Drag your files over and drop them into the directory.
Nov 09, 2008 | Maxtor Hard Drive
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
