Question about LG Washing Machines
Install front seal on LG WC - 1018 WD - 1049c washing machine
I have removed the seal, front & rear spring cables... How do I get them back in? Do I need to take the front off the machine or should I lie the machine on it's back? Please help? Thanking you all for your help in advance, Jaynee jayjaynee@hotmail.com
  • Jaynee M Nov 11, 2012
    Thank you Richard, I had watched that which is how I knew how to remove the seal. However that is a very different type of machine to mine. Mine is a LG WC - 1018 D - 1049c and the screws are not in the panel places that they are on this video. pleeease help me! Jaynee
    Top Expert:
  • LG Master
  • 9,472 Answers
See if this video helps you out.
Posted on Nov 09, 2012
  • 209 Answers
SOURCE: bosch washing machine
i am recently retired appliance engineer of 20 years, the rear door seal clamp is generally nowadays a large thin spring that is slightly hidden by the concrete weights at the front of the drum, if thats the case the door seal will just come off with a good firm pull round the drum edge, fitting as a reverse of removal, place the door seal in the groove so it fits like it should, then stretch the spring and fit that into the outer groove round the lip of the door seal at the drum end, once that is done fit the seal on the front panel lip, then replace that clamp, check all is fitted securely before running machine its one of those jobs that hard to explain how to do it, hope i have helped a bit, its easier to work through the front door opening than from above? if i have please rate me thank you
Posted on Sep 13, 2007
smilemaker
  • 790 Answers
SOURCE: Problem with LG WD-8023FB washing machine
Hello sir,
  1. If a washing machine is rumbling, and very **isy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  2. A**ther drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is **t always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  3. Loud **ises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would **rmally be a loud **ise on each revolution of the drum whereas the **ise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  4. Coins or other obstructions trapped inside the tub under the drum can make horrendous **ises as they get tossed about on spin. They often don't make the **ise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and **t actually be the cause of the **ise at this time
  5. Other causes of a **isy washing machine are coins and other obstructions inside the water pump. This will cause **ise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of **ise on spin as the coins get tossed around inside. Often, spinning the drum by hand will **t reproduce the **ise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  6. A light scraping or ratchity **ise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  7. A high pitched squealing or harsh **ise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  8. A k**cking **ise can be a loose tub weight. This would **rmally be worse with heavy loads and would **t be present on spin with ** washing in. This is because the k**cking **ise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. A**ther symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early e**ugh
  9. Sometimes a badly worn drive belt can cause a surprising amount of **ise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find ** **ise.
Posted on Mar 10, 2008
SOURCE: Error display "CL" - what to do?
THe child lock is on. Mine came on for some random reason. On my LG front loader there is a button on the right hand side with a cartoony picture of a child and a padlock. Press this.
Posted on Sep 12, 2008
SOURCE: LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Posted on Nov 23, 2008
  • 236 Answers
SOURCE: LG WD-1049C Front Load Washing Machine Pump impeller sloppy
probably better change the pump if you feel any up and down slack in the impellor. you may have an ingress of water through the seal.
Posted on Mar 13, 2009
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
1997 Ford contour rear brake shoe replacment help.
Brake shoe removel:
Depress and turn the retainers for the hold-down springs and pins to remove them from each shoe. Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Step 4 Pull the parking brake cable spring back with diagonal cutting pliers, grip the cable with the pliers without cutting it, unhook the cable from the parking brake lever and remove the rear brake shoe with the lever.
  • Step 5 Disconnect the parking brake lever from the rear shoe by spreading the retaining clip with a screwdriver and removing the clip and its spring washer.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xgUqun
  • Step 3 Unhook the lower retracting spring from the front brake shoe to disconnect it. Spread the shoes apart at the bottom to remove the adjusting screw, the screw's retracting spring and the adjuster lever. Remove the front brake shoe.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xdByQ8
  • Step 2 Slide the brake shoe assembly--including the shoes and springs--down so you can disengage the top ends of the shoes from the cylinder and tilt them to lift them past the retaining plate.
  • Read more: How to Change Rear Brakes on a 1997 Ford Taurus | eHow.com http://www.ehow.com/how_6123373_change-brakes-1997-ford-taurus.html#ixzz0u2xVyUAt
    Jul 17, 2010 | 1995 Ford Contour
    How do you get the gasket our of an lg wd-1049c
    You will find this link helpful
    We have a Free full video library on appliance repair video’s
    and here is a link to our door seal section
    and here is a video on door seal changes
    Jan 13, 2010 | LG Washing Machines
    Message CL has appeared whch is child lcok. How
    hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
    Nov 12, 2009 | LG WD-1045FH Front Load Washer
    I have a 94 jeep wrangler front left axle seal bad. I took the left side apart and not sure how to get the seal back in. Do I need to open the inspection cover on the diff. and take the gears out?
    Rear Axle Notes
    1. Raise and support vehicle.
    2. Remove rear wheels.
    3. Scribe alignment marks on propeller shaft and axle for proper assembly, then disconnect propeller shaft from axle.
    4. Disconnect the track bar from axle mounting bracket.
    5. Disconnect parking brake cable at equalizer.
    6. Disconnect shock absorbers at axle tubes.
    7. Disconnect hydraulic brake hose at rear axle Tee-fitting, then tape ends of hose and fitting to prevent contamination.
    8. Disconnect axle vent tube from axle.
    9. Remove U-bolts and tie plates.
    10. Loosen spring mounting bolts.
    11. If equipped, disconnect ABS wiring connections at axle.
    12. Support axle with suitable jack.
    13. Remove spring-to-shackle attaching bolts and lower spring to the floor.
    14. Remove axle assembly.
    15. Reverse procedure to install.
    Front Axle Notes
    1. Raise and support vehicle at frame behind front springs.
    2. Remove front wheels.
    3. Scribe alignment marks on propeller shaft and axle yoke for proper assembly, then disconnect propeller shaft at axle yoke.
    4. Disconnect connecting rod at steering knuckles.
    5. Disconnect shock absorbers at axle housing.
    6. Remove stabilizer bar connecting links to spring tie plates attaching bolts, if equipped.
    7. Disconnect breather tube at axle housing.
    8. Disconnect stabilizer bar link bolts at spring clips.
    9. Remove disc brake calipers, rotors and brake shields.
    10. Remove U-bolts and tie plates.
    11. Support axle assembly with suitable jack to relieve spring tension.
    12. Loosen rear spring shackle to spring attaching bolts.
    13. Remove front spring shackle to spring attaching bolts and lower spring to floor.
    14. Remove axle from under vehicle.
    Jul 21, 2009 | 1994 Jeep Wrangler
    How do i change a door seal on a wma35 hotpoint washing machine
    it can be changed through the porthole itself tho i find it easier myself to remove the front of machine as everything is easilly accesable that way ... once the bezzel has been removed the front is held by 4 self tappers remove these and lift front upwards to remove it from holding tags .. the seal itself is held by a large metal band you will see this quite clearly now ...
    Jul 06, 2009 | Hotpoint WMA35 Front Load Washer
    Washing Machines Logo
    271 people viewed this question
    Top LG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
