Power issues on a desktop PC.
On turning on my PC, it turns off in 1 sec. It repeatedly does this when trying to turn it back on. At times the system turns on however theres no display. At at times the system works fine. At times it hangs on BIOS, at times on windows. Does any1 know what the fault can be. I'll be grateful.
  • SD Tech
    SD Tech Nov 08, 2012
    is it possible that when unit does come on after several tries and stays on it will work until you turn off and it cools and then the issue starts all over?
  • joecoolvette
    joecoolvette Nov 08, 2012
    I would like you to look at the Radial Aluminum Electrolytic Capacitors on the motherboard,http://capacitorlab.com/visible-failures... unplugged from power, Anti-Static Precautions -> FOLLOWED. You may have to use a flashlight, and you MAY have to remove the motherboard, to get an accurate diagnosis. Post back in a Comment.
  • 27,725 Answers
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Nov 09, 2012
4 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: lg l1710 inverter board fault
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on May 01, 2008
  • 51 Answers
SOURCE: A display problem in my Acer desktop pc
techguru 2009: First thing disconnect all power. Remove all drives (hard drive, CD/DVD, Floppy). Then remove all PCI cards. Also slowly remove the Memory cards. You should only have the motherboard w/processor and the power supply connected, do not connect the monitor or mouse\keyboard. If you have a CMOS battery also remove it. Careful turn the power on, you should hear several beeps. That is letting you know that there is no memory installed. Turn power off disconnect power cord. Slowly install the memory cards, keyboard, mouse, monitor. If you have a pci video card install it now. Turn power on. you should see the bios loading then error message there is no disk or operating syste. turn power off and start connecting one device at a time so your bios can recognize it. This should let you know if you have faulty hardwareby isolating each install. If you still have problems let me know.
Posted on Feb 24, 2009
SOURCE: gateway gt5648e desktop power
I had temporarily solved this problem on my PC. After much research I've learned that Gateway shipped these PC's with faulty bios. What you will notice is that your machine will "loud fan reboot" every hour like clock work. Either clock in manually or use your system tools to see the exact reboots and manually reboot a minute before it shuts itself down. This has worked for myself and many others on various boards if you google the problem.
Weird? Yes!! But it worked !!! 2 months reboot free.
Posted on May 05, 2009
Laptop does not turn on . press power button , green light comes on for two secs then turns off. ACER aspire 5570 2067
possible causes
bios battery dead / symptoms: system won't start
have you just installed new ram memory if so take out the new card and put it back in again, might not have seated properly
try pressing various keys in the f-row at the same time you power on
curse at pc repeatedly while you try these steps (especially the last one, for some reason it seems to help)
Oct 06, 2010 | Acer Computers & Internet
Tip
How to preform a key relearn for gm cars and trucks
a relearn of the key is done with the ebrake up to keep the day time running lights off ( not an issue for you) but do it anyway. put key in the ignition and turn it to the on position right before crank for 10 sec. turn it off for 10 sec. then turn it back on for 10 mins. repeat two more times back off for 10 sec.and then back on for 10 mins. it is cruishle you try to keep with in the times or very close. 10 seconds and 10 minutes three times and that will relearn the key.
this will work for passlock 2 systems and newer.
on Jan 04, 2010 | Pontiac Grand Am Cars & Trucks
My computer starts to load and when it gets to the blue windows xp screen it stops and does not load into windows.
Turn off your computer by holding down the power button (10 sec.)
Turn the computer back on and Hold down the F8 button at the top of your keyboard, until the start up menu shows, Then select "Last known Configuration that worked"
If that does work you can repeat the steps and try system restore if you have it enabled.
If still unable to load you would need service, or to reinstall windows
Sep 14, 2010 | Dell Dimension 4500 PC Desktop
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
Gateway gt4010, wont power on.
The fan turning off will be the cause of the PC shutting down.
This could be caused by a faulty fan or bad connection to motherboard.
1. try reseating the fans power plug on the motherboard
2. if that doesn't help, try replacing with new fan.
3. if that doesn't work then most likely motherboard problem
Feb 11, 2010 | Gateway GT4010 (RBGT4010) PC Desktop
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
My HP Pavillion entertainment PC laptop does not turn on. the charging light comes on when connected to electric outlet, but when I turn on power button, the top buttons light up for 1 sec then everything...
Hi cgafinest,
I had a similiar issue some months ago. I replaced the power supply and fixed the problem. You may want to try that first.
Hope this helps and good luck.
Aug 02, 2008 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
