Question about ASUS M2N68-AM SE2 Motherboard
Im trying change power supply but nothing happen.. please help i need it...
  • ASUS Master
  • 3,606 Answers
Hello try to download a manual if you don`t have one:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=24&m=M2N68-AM+SE2&os=25&hashedid=rzWjxRHTivB96wPd
Please select your operating system
Select manual and hit global for download
The file needs to be unziped.
Does there come any beeps ??
The mainboard has a green led does that lid green or red ??
And the power supply to the board
did you connect the cable right ??
You can not connect the 24 pin cable wrong.
But you can connect the cable for the power supply 12+ wrong.
The pci-e cable sometimes fit in the socket.This is for a external
graphic card for extra power.
If you have connected this wrong the mainboard will not boot.
Please check all the cable is set correctly assisted by the manual.
If no luck the mainboard just died.
Good luck
Posted on Nov 08, 2012
joey64
  • 209 Answers
SOURCE: p4v8x-x bios dont boot
your problem is in video card, try to remove and clean the connectors (bronze color) with an eraser. then re-install, if the problem still occurs try to hear beep (warning sound). we have different sound for the installed hardwares such as the memory card, video card and the boot sound. if you have installed an expansion video card remove this and use your on board video card to determine if the video card you installed is defective. and if you are using the on board video card install a new video card
Posted on Oct 22, 2007
colliewob
  • 778 Answers
SOURCE: ASUS Crosshair won't boot
some motherboard have 2 power supply plugs 1 for board 1 for cpu check and see if yours is like this 1 is a wide one with about 15/20 pins in the other is asmall square one with 4 pins
Posted on Jul 26, 2008
  • 6 Answers
SOURCE: ASUS p5vdc-MX motherboard won't boot
The light is probably the power light which is ok, but from past experience it sounds like the board is dead for one reason or other. Is it still under warranty? If it is take it back to where you got it, with the purchase docket if you have it and talk to them about what you have tested and ask for a replacement. If it is out of warranty, try ebay or use www.staticice.com.au to search for the same motherboard if you want to rebuild the system without having to reload windows.
Posted on Feb 09, 2009
rtrahan
  • 741 Answers
SOURCE: ASUS P5GD1-VM motherboard not booting when powered on
First are you sure it is the CPU fan and not the Power Supply fan? Open up the case and make sure the power supply cable is snug into the slot. Make sure that Pin 1 is lined up with Pin 1 on the motherboard. There should be a notch or red dot or different looking Pin to show you where pin 1 is...sounds like it may be a connection problem from power supply to motherboard...try that and let me know what happens we have other options but have to start somewhere..
Posted on Mar 06, 2009
hmerchant110
  • 7191 Answers
SOURCE: ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Posted on Jul 21, 2009
I just changed altrnater on a,2003 accent and the battery is,good im still not gettn ne,power no lites no nothin and the shiftr wont move out of park someone pkiz help
BATTERY CAN BE BRAND NEW, BUT IF WIRES ARE OLD , LOOSE, OR CORRODED EXCESSIVELY YOUR GOING TO HAVE PROBLEMS. ALSO CHECK FUSIBLE LINKS, & STARTER RELAY.
Dec 25, 2012 | Cars & Trucks
My cpu wont turn on
hi im josh in cebu phils.may i help you? Friend nothing happens to your motherboard or cannot completely open when the supply current is not enough to support or provide the mainboard.especially if there are many devices attached such as video cards dvd rm etc. you need more power to make them work. so you need to change or use a power supply having a output.500w up.for better good luck hope i helped you.vote so that i'll know if i did it so.
Feb 23, 2009 | HP (5185-6477) Motherboard
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
My printer is slow what should i do? HP PSC 1410 All-In-One
This may be caused by your computer, it may need to be defragmented or to upgrade your hardware and/or operating system.
Feb 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
RED SCREEN
Water damage irreversible - it might work sometimes
Oct 04, 2007 | SanDisk Sansa e200 MP3 Player
My dryers not working
If one of the lines is lost (230v circuits have to hot lines) the light only works on 1 line check your connections. There is also a thermal fuse that shuts the machine down when its overheating. If there is 230v at terminal block. The fuse is what i check next, well doorswitch too make sure the switch isnt broken (upper right of door). PLEASE RATE MY HELP
Oct 02, 2007 | Dryers
HELP
What happens when you power on the player? If just the blue ring lights up and NO screen activity, and you've already tried the recovery mode (hold switch, hold REC, power on) then you need to send the unit back provided that it has been purchased within the year. Unfortunately the only software tool where you can hook up a unit and have the software force flash it to a repaired state is a sansa connect. The e2xx series does not have any assistance/repair software available for download. I know that this isn't a technical solve but technically you can't fix this as it's solid state technology. So please don't flame me for helping. I got a "no help" vote because they had a dead MLB on a PC. Thanks in advance. (RMA# support is 1-866-726-3475)
Aug 19, 2007 | SanDisk Sansa e260 MP3 Player
ASUS M2N68-AM SE2 Motherboard Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
