Question about JVC Model Sea-v7e - 4 Channel Sea Controller Equalizer
What does the S.E.A controller functionality in an equalizer stands for?
Are the systems A and B working parallel or sequenciel on the channels?
What is the best way to wire two kicker comp r 12' s to a two channel amp for max bass?
First, you need to know whether you have the 2 ohm DVC subs or 4 ohm DVC subs. Second, you need to know the minimum impedance the amp can handle (most are 2 ohm, some are less). Putting two voice coils in parallel will cut the total impedance in half (e.g. 2x 4 ohm voice coils in parallel = 2 ohms total). Putting subs in parallel will also cut the impedance in half.
At one end of the spectrum, you could put the 2 ohms DVCs in parallel, then parallel the two subs, and bridge the 2 channels of the amp. That would put 0.5 ohms impedance on the 1 bridge amp channel. If the amp can do 0.5 ohms x 1ch, do it. Otherwise, you may have to run the subs on separate channels.
Oct 23, 2015 | Kicker Car Audio & Video
Do you bridge a 850.4 four channel amp when it is 2 ohm stable and ur subs are wired up as series/ parallel and there 2 ohm dual voice coil speakers
If you wire 2 ohm dvc speaker parallel that would give you a 1 ohm load. If your amp is only 2 ohm stable that would not work. You would have to wire the speaker in series giving you a 4 ohm load. Then you can bridge the 4 channels into 2 with each speaker running at 4 ohms.
If you want to run a 2 ohm load use all 4 channels on amp and speakers. No need to bridge.
For 2 ohm DVC:
Parallel = connect both + and - together. = 1 ohm
Series = connect + from 1 channel to - from the other channel. = 4 ohm.
Jul 06, 2014 | Car Audio & Video
How do I wire up my 4subs in bridged to my peace 2600
Please state the subs impedance, but assuming 4 subs with 8Ohm Voice Coil you CAN'T run them in parallel in Bridge Mono because this amp's minimum impedance is 4Ohm in bridge and 2Ohm stereo, maybe a series/parallel connection work, but what's the advantage to run them in Bridge mode? This amp delivers 900W per channel at 4Ohm, you can run a pair paralleled for each channel in a safe way and without the high-risk of your amp being destroyed, besides, amp power at 4Ohm Bridged is NOT recommended for continuous use, let me know your results...
May 13, 2012 | Peavey Pv 2600 Power Amplifier
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 | Music
Bass speaker not working. Sub woofer connection not producing current to allow Bass speaker to work.Would like to try to connect to 6 channel set up but not sure how that's done since I have the speakers...
make sure speaker voice coil are still good...continuity checks will confirm this....as far as 6 channel hook up, you need to know what the lowest impedance allowed is from your system and then wire up your speakers in series /parallel to come up with a final impedance that will very closely match the systems minimum output impedance
Aug 15, 2009 | Yamaha HTR-5730 Receiver
Two 4-OHM DVC AND two 4-ohm
your amp is stable at 2ohm in stereo mode . you can wire them in series or parallel. series you add up the ohms . parallel you use this (R1+R2)divided by(R1xR2)=total resistance this figures two speakers at a time to add more speakers after total repeat formula as long as you don't go below min load you are fine . in your case all speakers in parallel you would be running 0 ohms bad . in series you would be running 16 ohms stable but not even half the power of your amp. if you hook up two in parallel and two in series on one channel you are running 1.6 ohms still not stable.If i was u I would hook up two 4ohm speakers in parallel on one channel and two in parallel on the other given you a stable 2ohm per channel.
total power output per channel 1200w
Jun 20, 2009 | Behringer EUROPOWER EP2500 Amplifier
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Running 4 12s with two insignia 1000 watt amps
Use a pair of two-channel amps that are two-ohm stable, and wire a pair of subs to each amp. Wire them in parallel so the amps see two ohms (wiring in series will show four ohms). Doing this effectively "doubles" the power of the amps. If the amps are not two-ohm stable, they'll fail. Parallel wiring means putting the positive wire of sub 1 to the positive terminal of channel 1 on the amp, and the negative wire of sub 1 on the negative terminal of channel 2. Do the opposite for the second sub. This will give you a LOT of bass response as long as your sub enclosures are properly sized for the speakers.
Jul 21, 2008 | Insignia Car Audio & Video
Amp connection
Parallel would be the best way to wire them. 2 4 ohms subs to one channel wired parallel would be a 2 ohm load for that channel and if u wire them series then 2 4ohm subs to one channel would be an 8 ohm load for that channel.
May 31, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Speaker connections
Not usually. They are generally parallelled inside. But if it's the jack itself and not the amp channel thats broken, you should be able to use it successfully.
Sep 13, 2007 | Yamaha Emx88s Powered PA Mixer System
JVC Model Sea-v7e - 4 Channel Sea Controller Equalizer Logo
53 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
