Question about Sharp BQCXVZ100001 Projector Lamp for XV-Z10000
How to reset the timer on a sharp BQCXVZ1001 when changing bulb
Answer to above
  • BillBur Mar 12, 2009
    Following the procedure described on page 78 of the manual is not resetting the timer.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Posted on Sep 28, 2016
DT27 model won't turn on
1) DT27 timer is same as Kichler 15559.
I don't think either product is still available unless another company such as Brinks has taken over the design.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT27
2) Change LR44 batteries
And then reset timer by depressing reset button.
Reprogram.
Check light bulb is operable, and lamp switch is ON. Move timer to different outlet.
Check circuit breaker.
Plug in different lamp.
If functionality is not restored, then buy another timer such as Intermatic DT620 with lifetime warranty (shows just above DT27.)
3) Many timers today do not require battery and have internal rechargeable battery instead.
Timer designs change because CFL and LED bulbs are inductive loads, while many older timers were rated only for resistive loads such as incandescent bulbs.
Jan 28, 2013 | Intermatic Hardware & Accessories
I have replaced the lamp on my sharp xr-10x L. I cannot get the bulb to turn on I have lights so there is power but the lamp is not on.
You must reset the lamp timer. Check the manual or sharp website for instruction how to reset the timer after changing the lamp
Aug 07, 2010 | Sharp XR10XL DLP Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
I just changed the bulb in my sharp xr-11xc. it worked fine till i turned it off and now its not working again
reset the lamp timer. hold down the menu, down arrow, and enter buttons, then press power.
Nov 20, 2009 | Sharp XR-11XC Multimedia Projector
How to change sharp xv-120zu bulb
Jun 07, 2009 | Sharp (RLMPF0005CEZZ) Projector Lamp for...
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Flashing leds no picture
when You changed the bulb  you have to reset the bulb timer , that why the light is flashing red , look at your manual and reset the timer , and the picture , changed bulbs myself before i found what the problem was ,
Mar 25, 2008 | Sharp XR-10X Multimedia Projector
Does not turn on
the unit has an internal timer , this has happened to me several times  , i changed bulbs thinking that was the problem , when the bulb timer reaches 2000 hrs or the if you change bulbs and dont reset it the machine will not respond , check your manual and reset the timer
Oct 07, 2007 | Sharp XR-10X Multimedia Projector
Sharp BQCXVZ100001 Projector Lamp for XV-Z10000 Logo
258 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
