Question about White Sewing Sewing Machines
White sewing machine model 1044 thread keeps breaking
bargainbox
  • 1388 Answers
SOURCE: HUSKY DELUXE SEWING MACHINE
Your local Husky dealer or via their head office in your country ought to be helpful unless they are out of print.........if so, ......Try sewusa.com or sew4less.com
Posted on Jun 02, 2008
  • 47 Answers
SOURCE: How to Thread the bobbin on my sewing machine
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Posted on Jul 24, 2009
SOURCE: thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Posted on Sep 23, 2009
  • 1116 Answers
SOURCE: need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Posted on Feb 20, 2010
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
Breaking thread on Bernette sewing machine model 200B
Is there too much drag on the thread?
Please click the Comment link to respond.
May 12, 2018 | Sewing Machines
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
My thread keeps breaking when I sew
Tension is maladjusted. There is a tensioner on the front of your machine. If it is too tight (turned clockwise) the thread will break. Also could be the bobbin has tangled. Remove it and check for tangles.
Aug 18, 2012 | White Sewing Fashionaire Sewing 2380...
Bottom thread keep breaking , sew an inch then break !!
Make sure that the needle is all the way up in the needle bar.
Unscrew until just loose, use finger nail or small screw driver to push up on the needle. The two needles do not line up.The right needle extends longer. Also, make sure that there are no burs on the needles and that they are straight and correct for your machine.
Apr 28, 2009 | White Sewing Superlock 1934D Mechanical...
Thread keeps breaking
Your machine isn't threaded properly. Check to make sure #1, you have it threaded right and #2 the thread on all 4 spools is in between the tension dials. Good Luck and Hope this helps.
Aug 24, 2008 | White Sewing Speedylock 1600 Mechanical...
Keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
Apr 06, 2008 | White Sewing Speedylock 1600 Mechanical...
Open Questions:
Sewing Machines Logo
131 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
