Question about Whirlpool WGD5600XW Cabrio 27" Front-Load Gas Dryer with 7.4 cu
Whirlpool Carbrio dryer buzzing noise while running. Works OK just keeps buzzing off and on while drying. Not a grinding sound.
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
  • 85 Answers
SOURCE: Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Posted on Dec 16, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
  • 7 Answers
SOURCE: whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
is the dryer tumbling
Posted on Jun 12, 2009
garing
  • 998 Answers
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Posted on Aug 27, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
OK, remove the 2 screws on the front lower kick plate. Run the dryer to see if the buzzing is coming from the motor or from the burner area. Post back your results.
Nov 09, 2012 | Whirlpool WGD5600XW Cabrio 27" Front-Load...
Whirlpool duet dryer makes a horrible grinding noise while running. Clothes still get dry but drives us insane!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 29, 2011 | Dryers
I have a Whirlpool Duet Dryer (Model EW9200LL1) that is about five years old. It is getting increasingly noise when drying--sounds like a belt or bearing issue. Is this something I can troubleshoot/repair...
heatman101
Asker
Nov 22, 2010 | Whirlpool Dryers
Whirlpool Estate gas dryer dries but has a loud rattling sound when its in operation.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 11, 2010 | Estate TGDX640JQ Gas Dryer
I tried to start the dryer (whirlpool LE5700XK or the LG5701XK, not sure which) and when I hit the start button there was a loud buzzing noise, but no start. I turned the dial to the off position, and then...
Could be a couple things, depending on the buzz you are getting, if it's a buzz from the board like an alarm, it could be a door switch, if it's an electric sounding humming buzz it could be something stuck in your blower wheel like a sock
Jun 24, 2017 | Whirlpool Dryers
Dryer makes loud grinding noise when you cut it on
The dryers drum runs off a belt as you may know to spin it around to dry clothes. This belt is attached to a belt tensioner also to keep the belt snug. This tensioner has a roller with a bearing in the middle of it. Most bearings are made of brass and wear out causing it to grind
I would replace the belt & tensioner pulley as a unit. Sears will have these two parts selling together as a kit. Go online to view with your make and model number to see
May 31, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Sport Gas Dryer - Works fine but makes loud noise
heatman101
yriur
Nov 24, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Noise from washing machine
heatman101
fddfs
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Whirlpool WGD5600XW Cabrio 27" Front-Load Gas Dryer with 7.4 cu Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
