TOSHIBA MK5065GSXN error - Computers & Internet
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Posted on Nov 08, 2012
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
Error code c280 of toshiba e-studio230
Code C280 Description Carriage home position sensor not going ON within a specified time try here about half way down page.
http://mresetprint.blogspot.com.au/2013/03/toshiba-error-codes.html
Toshiba Error codes mresetprint
Apr 06, 2016 | Toshiba e-STUDIO230 All-In-One Laser...
What does code error cd71 mean?
HI Jamshed, This is a TOSHIBA error...
http://www.mytechtime.com/2011/04/toshiba-errors.html
You will have to contact toshiba support... go to the Toshiba site and click on support.
Sep 07, 2015 | Office Equipment & Supplies
No connection between my internal hard disk and my laptop
Hi
The ref number you give is for the hard drive only and not related to the laptop, so I can only be fairly general. Often on laptops the hard drive is fairly easy to get at and I would first check that the drive is securely seated and firmly connected to the SATA connection inside the computer. Remove the battery before removing the drive cover.
If it is securely connected, try powering up again. If this doesn't work, power the machine off completely by holding the power button down for about 10 secs. Press the button again and during the early part of the boot up sequence press the relevant button to enter the BIOS programme. I can't be sure which particular key starts IOS setup for your computer as they vary quite a lot. Your manual will tell you however. On my Toshiba for example its the Esc key, on others its the F2 key, and others the Del key.
Once in the BIOS you should be able to navigate through the settings and find out if your drive is being recognised at this level. If it is then try to boot into "Safe Mode" to repair the installation, otherwise it probably needs to be reformatted and the recovery disks used to revert to factory settings. If you do this you will lose all your data and non Toshiba programmes that you have installed.
If your drive is not recognised in the BIOS, it is highly probable that the drive has become faulty and needs replacing.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
Toshiba satellite pxe-m0f
I would check the hdd is OK and not full of errors. When you press F8 just before boot can you select restore? If you can the restore partition is OK and it will restore itself to factory condition. If you can't, re run your restore discs or use an OS disc and install drivers when you get online.
Mar 19, 2014 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
Toshiba mk5065gsxn smart failure
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now ,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
Hope this helps.
Nov 29, 2012 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
