Question about Car Audio & Video
Kdc-238/CR speakers suddenly no sound out of speakers, subs work fine
My 97 thunderbird has a kenwood kedc-mp238/cr installed as the head unit, suddenly girl friend claims she used the src button and now i no matter what i do no sound from the speakers, but the subs work perfectly still. ive reset the unit and have removed power from the vehicle for over 30 min and still no sound from oem placement of kicker speakers. the mtx subs and mtx amp work perfectly. what ever i try i cant get the speakers to work.
  • scott crump Nov 10, 2012
    ok worked all night last night, took the car to car tunze today, thought the unit was bad, nope after several more hours of working to trouble shoot the problem with three proffessionals, i removed the door panels and we checked each speaker, turns out a simple blown speaker was the problem. on your unit i would suggest calling the kenwood customer service line wich i did as well. their are trouble shooting guides on their web site as well, i suggest you reset the head unit and if that doesnt work call customer service tech support. the guy was very helpful. i am middle aged and have been doing car stereos for over 30 yrs, kenwood is one of the units ive never seen go bad. pioneer has always sucked and clarion good for 5 yrs or less. oem usually good for the life of the car.
    I found th problem today and its fixed, my problem was as simple as a blown speaker. However durring the proccess of elimination I am sure the problem with your unit is the pig tail. Your battery power wire or you have a very bad ground. We rewired the pig tail first and we should had merely just checked the speakers. If just one is blown 0 will work as per system shut down protection. So double check your ground, then rewire the pig tail and definately check your power and ground wires. I believe that your harness or connector or "pig tail is bad" causing your issue, but don't rule out the oem speaker wires make sure u check them. On the thunderbird it has to have a stock jvc sound system to have an amp for the oem speakers.
KaeZoo
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
hawkwatcher
  • 67 Answers
SOURCE: my kenwood kdc-mp235
I assume the amp is turning on (lighting up) No audio may be due to Burnt rca ground trace in your kenwood radio. If you have a ohm meter measure continuity from rca's ground terminal to radio chassis. Should be close to zero resistance. If there is no no continuity there are fusible traces on radios main board that burn open at times when to much current is flowing thru rca ground
Just a good possibility , haver seen this happedmany times.
If you need service manual let me know kstahl65@att.net
Posted on Jan 26, 2008
  • 34 Answers
SOURCE: FIND RESET ON KENWOOD KDC-138/CR
try disconnecting your car battery if all else fails if you absoulutely cant find reset. dont forget to reconnect the battery however lol.
Posted on May 06, 2009
  • 18 Answers
SOURCE: cant seem to get the aux up on my kenwood kdc-237
Its becuase the aux is turned off as default so you have to activate it.
Put the unit into standby mode
Press menu for at least a second untill menu appears and then select the aux option and edit it to either aux on1 or aux on2 or aux off.
Anyproblems and you can download the pdf for free from internet
Posted on Jul 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: ineed a manual user guide Kenwood kdc 128 cr
You can get your manual here:
http://audio.manualsonline.com/manuals/mfg/kenwood/kdc-128.html
Posted on Nov 23, 2009
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
I have a kenwood kdc-mp238 and when i turn it on it says enter code. Well i have no idea what the code is. The other numbers on the head unit were m4x8mmmax
Kenwood I am afraid ask you to activate a code of your choice after purchase. The code you or the original keeper entered is NOT retrievable unless noted somewhere in your manual. This means the unit has to be taken/sent to a dealer for a "bench" re-coding.
Mar 27, 2011 | Kenwood KDC-MP238 CD Player
KDC-MP238?CR when I push bbbost to get the menu it immediately goes to DIM Off/onn and onbe other, OI cannot just get the menu to come up so that I can turn off the demo mode.
Press the B.Boost button and keep pressed for over a second but do this, when the head unit is in Standby mode. Hope that helps dreamsystems
Feb 11, 2011 | Kenwood KDC-MP238 CD Player
Kenwood kdc-138, NO SOUND, CD PLAYER NO RESPONDING
First thing you need to do is make sure you dont have a short in the speaker wires.. if any one of them touches ground it kills the system.. then you have to remove all the wires and start over... disconnect the battery... remove all the speaker wires only and then turn it on and reset it... then again remove the battery from the car and install them all make sure nothing is touching then turn it back on and see if that works.. you can also test to make sure you speaker wires are good by using a 9v battery and touching positive and negative of each speaker to the positive and neg of the battery... JUST FOR A SECOND it will pop.. that means your wires are good and no shorted to that speaker.
May 12, 2010 | Kenwood KDC-138 FM / AM Receiver
Kdc 238 cant get clock to display on screen
how can i convert the frequency from impair to pair the model of the is KDC-MP238
Jun 17, 2009 | Kenwood KDC-MP238 CD Player
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
I have a KDC-138/cr. I installed it fine and was adjusting the balance, turned the system back off and on and now I have no output to my speakers.
do you have an owners manual -- ? I have a copy of you need one.. just send me your email address and I will forward it to you
Dec 13, 2008 | Kenwood KDC-138 FM / AM Receiver
Car Audio & Video Logo
146 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
