Question about Dell in2020mb - 20in Wide Flat Panel Lcd Pn In2020mb
How to disassemble Dell IN2020M monitor stepwise & precautions
I want full details about how to disassemble the monitor and precautions that need to be taken while dis assembling and also tools recomended to use
2 Suggested Answers
SOURCE: how to disassemble monitor Dell 1800fp ?
Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
Posted on Jul 15, 2009
How do I unlock my dell in2020m monitor screen?
Press and hold the button above the power button for 10 seconds. You can download the manual here... http://www.manualslib.com/manual/506179/Dell-In2020m.html
Jul 21, 2014 | Dell Computers & Internet
My dell IN 2020 M monitor goes off after 4-5 min...i tried reducing brightness to zero ...it worked just for one day but now again the same problem starts....plz give some suggestions...
Dear Kumar, First of all make sure your laptop is not getting extra heat?
and most probably this issue is with your Graphic Chip.
you have to take it to any hardware export.
PS: Its recommended to visit Dell Authorised Service Center, otherwise this issue is much sensitive and will keep coming after few days even after the chip replacement.
Nov 02, 2013 | Dell IN2020M Monitor
Dell inspiron n 4010 hangs often
I suggest you open the laptop, and clean it out first. THEN go on with the diagnoses.
Dell Support > Inspiron n4010 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insN4010/en/sm/index.htm
1) FIRST remove all power. Remove the AC adapter (Charger) and Battery.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components on a computer.
Relieve your body of Static.
You should use an ESD wrist strap, and connect it's alligator clip to a good ground source.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
This pictorial guide for disassembly of an Inspiron n5010, should help also.
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/comment-page-1/#comments
The screws, and cables, etc., are in a different place, but disassembly is still the same.
Use a can, or two, of compressed air for computers.
Also you may wish to use Q-tips, and a soft small brush.
(Makeup brush? )
DO NOT use a vacuum!!!!
A vacuum creates Static electricity.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 15, 2012 | Dell Inspiron 14 Laptop Computer (Intel...
How to get the disk out of the computer
Hi there. Are you referring to the hard drive or cd? In any case, you may follow the guide from support site of dell, download the service manual to get detailed instructions on how to disassemble/assemble and install hardware for your laptop, please click below link.
http://support.dell.com/support/edocs/systems/ins1525/en/index.htm
Hope this helps. Goodluck and be sure to take necessary precautions before working with your laptop.
Nov 16, 2011 | Dell Inspiron 1525 Laptop
Where are the sound speakers on my dell in2020M or do i purchase them seperately.thanks
You need seperate speakers for these. There should be a green socket in the back of the PC, which is where you can plug in the speakers.
Jul 23, 2011 | Dell Inspiron 530 Desktop Computer
How do i replace the bulb in my dell e153fp monitor?
Are you sure it is CCFL problem not the shorted out transistors or blown fuse in the inverter circuits?
LCD will have to be disassembled to get the lamp assemblies out and you need to get the raw lamps from www.lcdparts.com
, remove the old wires an resolder the wires back on to the new lamps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Sep 01, 2010 | Dell E153FP 15" LCD Monitor
The on/off button on my 22" Dell monitor no longer works. How do I get behind the outer casing to locate the probel & fix it?
guest, could also be a bad fuse inside monitor. Is monitor 22 inch CRT or LCD type monitor?? Try to find disassembly DIY video of monitor at YOUTUBE first!!! There are some that are very good to watch. 12fixlouie
May 19, 2010 | Computers & Internet
Dell latitude d60..the laptop wont display without external monit
Seems that you have a loose LCD screen cable connection. You will need to disassemble the laptop & make sure the LCD screen cable connection is tight.
Please check this link for more details:
http://www.laptopparts101.com/lcd-screen-video-cable/
Feb 23, 2010 | Dell Latitude D600 Notebook
I have inspiron 9300 and my screen has developed 5 vertical lines.repair or replace and cost please
Usually this issue isn't repairable, but is fixable by replacing the screen. This can cost from $75-$200 for parts depending on your model alone.
There are a couple on E-Bay for about $100-$125 for your model. I would recommend finding someone that has experience replacing computer monitors.
If you feel comfortable replacing it yourself (make sure you take the necessary precautions), you can find the Service Manual from Dell with disassembly instructions at the following link.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 26, 2009 | Dell Inspiron 9300 Notebook
No power
OK disassemble the monitor and visually check for bad components or cold solder here is a couple of examples.3bf0ae5.gifcold solder12cd393.jpeg bad capacitor
Jul 05, 2009 | Dell M992 Monitor
Dell in2020mb - 20in Wide Flat Panel Lcd Pn In2020mb Logo
366 people viewed this question
Alun Cox
